radiator shroud selection - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 28th, 02, 11:23 PM Thread Starter
I have a 1968 Camaro with a 1972 motor. If I replace the radiator, do I get a radiator for the 68, or do I buy one for a 69 since I have the long water pump? Same for the shroud, if it is wrong, which would I buy??
rodsters is offline
post #2 of 4 (permalink) Old Jun 30th, 02, 02:23 AM
Chris
130fe's Avatar
Rodsters, all first gen camaros came with either a 20 3/4 or 23 inch wide radiator. the 20 3/4 came in small blocks without a/c and the 23 ones came in big block and small blocks with air. Either will work for your application, but you have to get the correct fan shroud to make it fit correctly. A 20 3/4 fan shroud will "fit" on a 23 radiator but it looks kind of goofy and you have to "add" a bottom support (homemade bracket). Either way, try to get the correct fan shroud and it will look 10 times better. Let me know if you have anymore questions.
130fe
130fe is offline
post #3 of 4 (permalink) Old Jun 30th, 02, 08:08 PM
David Pozzi
davidpozzi's Avatar
A 69 shroud will work best with the long water pump.
There is an air cond version shroud and std version, depending on the radiator width you use.
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
post #4 of 4 (permalink) Old Jun 30th, 02, 09:16 PM Thread Starter
I had wondered what the difference was on air conditioned cars. I guess I'll go for the 23" radiator with the 69 SB shroud.
Thanks for your help.
rodsters is offline
