How to shim a starter? - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 6th, 02, 05:51 AM Thread Starter
Allmost Every time I try to start my 69 Camaro I get a click noise. After one or two trys the starter aligns correclty and I can start the car.
I am assuming that I need to shim the starter.
How do I shim the starter?
How do I know what side to shim?
Do I use washers to shim it?
jrager is offline
post #2 of 4 (permalink) Old Jun 6th, 02, 05:54 AM
Codi's Avatar
If you are getting just a "click" noise, it is not a starter shim problem. You may have a bad solenoid or cables. I would check them first. If the starter does try to engage the flywheel and you hear a grinding noise, or hear the starter spin, it my be a shim problem or starter drive problem. Autozone sells a shim kit in teh help section. They may also have several laying around from other starters.
Codi is offline
post #3 of 4 (permalink) Old Jun 6th, 02, 07:03 AM Thread Starter
Thank you. I will try replacing the solenoid tonight and check the cable. I will reply with the results.
jrager is offline
post #4 of 4 (permalink) Old Jun 6th, 02, 09:49 AM
check to see if your starter bolts are tight
nate
eggersn is offline
