94 Camaro not starting!!! - Team Camaro Tech
post #1 of 5 (permalink) Old May 14th, 02, 12:39 PM Thread Starter
I have a 6cyl 3.4 manual 5 speed, when i push the clutch in to start the car nothing happens, all the indicator lights come on, but the engine doesn't turn over.
When i push the clutch pedal in and out 2 or 3 times it catches and starts. This just started happening pretty frequently. Is it the starter?
Also i have rough idling and it feels like its missing when i accelerate usual tune up has been done. Any ideas?
GlimTwin73 is offline
post #2 of 5 (permalink) Old May 14th, 02, 01:06 PM
ZZ_430's Avatar
As far as the starting goes, there is a safety switch mounted on your clutch pedal...may just need an adjustment.
It also serves as a cruise control cut out.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #3 of 5 (permalink) Old May 15th, 02, 01:23 AM Thread Starter
Thanks for the info. where is the switch located on the pedal?
post #4 of 5 (permalink) Old May 15th, 02, 06:01 PM
ZZ_430's Avatar
You'll have to drop the "hush panel" that covers the top of the pedals.
You'll see a white switch attached to the clutch pedal.
That's the safety switch...use caution when working on it, because it's possible the car could crank in gear.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
ZZ_430 is offline
post #5 of 5 (permalink) Old May 16th, 02, 03:22 AM
probly wouldn't hurt to check for a corroded battery cable too
eggersn is offline
