i cant shift out of first gear - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 1st, 01, 07:01 PM Thread Starter
I have a turbo 350 and I can no longer shift into second manually. I now have to wait for the engine to almost redline for it to shift(on its own). I need some help. Thank you.
M. Cruz
CRUZ'in68 is offline
post #2 of 5 (permalink) Old Mar 1st, 01, 08:19 PM
Joe
Have you checked the fluid? If the fluid is okay, then check the governer in the side of the trans.
Radio Joe is offline
post #3 of 5 (permalink) Old Mar 2nd, 01, 04:55 AM
could also check to see if your vacuum line (?) to see if it has been bumped off. I had that problem before and it turned out that there was a little hose loose on the front of the trans. After I pushed it back on there, no problems anymore.
boodlefoof is offline
post #4 of 5 (permalink) Old Mar 2nd, 01, 05:30 AM
Can we all say vacuum module?
1st & 2nd GENGuy is offline
post #5 of 5 (permalink) Old Mar 2nd, 01, 05:31 AM
after governor, (remove and clean)They tend to get varnished up and stick, try a filter kit, theyre cheap and come with the gasket, and hope for the best.
Good luck
68ragtop is offline
