69 factory air not cooling very well - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 5th, 00, 11:05 AM Thread Starter
At idle the A/C blows cool, but not very hard, when driving the air gets lukewarm. It was converted to 134, it had not worked previously so I have nothing to compare it to. Should it get cold? The technician who did it said that would be as good as it gets. This is my first "old car" as my wife calls it so I have no baseline to compare it with. Any help would be appreciated.
kgb69 is offline
post #2 of 7 (permalink) Old Jul 5th, 00, 01:56 PM
Stick a thermoter in the AC vent, and run it full blast, the temp should drop to at least 50 degrees on a hot humid over 90 degree day, I was told rule of thumb on 134 system is 40 degrees below out side temp. Is your fan drawing enough air through the rad and condensor ( 7 blades?)
Rob.Canada is offline
post #3 of 7 (permalink) Old Jul 10th, 00, 08:05 AM Thread Starter
At idle the car cools very well, gets 40 - 50 degrees colder. When moving the air warms up quite a bit, only about 10 - 15 degrees cooler. On a 95 degree day at idle it got to 53 degrees, when moving it goes up to around 80 degrees. It holds pressure, it is has had around 4 pounds of 134a put in. It has a flex fan right now, but I have a thermal clutch and fan assembly on the way. I have been told this will help keep the engine temp down, it gets to around 210 with a 160 degree thermostat. I get the feeling I may need a bigger radiator. The shroud is intact. I might just be rambling now so I will sign off
kgb69 is offline
post #4 of 7 (permalink) Old Jul 10th, 00, 04:38 PM
David Pozzi
davidpozzi's Avatar
If the air gets too cold it will ice up the core in the ac box. Especially if there is humidity. The air flow will reduce to almost nothing.
Turning it off for a while would restore air flow and then you could turn the air cond on and it would be great for about 10 minutes or less, then air flow would go down.
I had this in a 72 corvette. The air cond was too cold. I can't remember if it was a thermal switch or overcharged.
Check my web page for suspension info:
David's Homepage
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #5 of 7 (permalink) Old Jul 10th, 00, 05:54 PM
When it was converted to 134a did the shop replace the dryer and orings? Just putting in 134a will not work without changing the orings, dryer also the orifice screen should be cleaned.
68SS ZZ4, 4sp T-10, 12 bolt, getting painted
78Z28, 330hp vortec, TH350, 10 bolt (just finished)
1st & 2nd GENGuy is offline
post #6 of 7 (permalink) Old Jul 11th, 00, 05:30 AM Thread Starter
The drier was changed, not sure about the o-rings, I would guess not. When talking to the previous owner and his trouble with the leak, which was fixed by the shop I took it to it seems he added quite a bit of oil. I am not sure why but he did. I have a theory now that there is simply too much oil, old and new in the system, so the shop I took it to said they would take the entire system apart and blow out all the oil out and replace all the o-rings as well. As for freezing up, that was my first thought, but the airflow doesn't drop off just the temp raises. Thanks for all the help, I will let you know after the shop looks at it if it works.
kgb69 is offline
post #7 of 7 (permalink) Old Jul 17th, 00, 12:42 PM Thread Starter
Smile
Well we pulled the entire system apart and drained quite a bit of oil. 5oz or so. Recharged with 3 cans of 134a and it gets down to 49 degrees on a 100 degrees day. I found new trouble however, seems I have some holes in the seams of my radiator, so it looks like new radiator time. But that will give me the chance to do a little cleaning up in the front. My wife is beginning to think I love my Camaro more than her, so she suggested I put a cot in the garage. She sure is funny that way.
For a quick glimpse of my car My home page
[This message has been edited by kgb69 (edited 07-17-2000).]
kgb69 is offline
