Alignment Problems - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 29th, 01, 08:32 AM Thread Starter
Angry
I have a 91 RS that constantly tracks to the right. The caster/camber is perfect but it still pulls. It wears the tire down fairly quickly. I suspected a sticking caliper so I replaced the rotor, pads, hoses and caliper and it still pulls. After these replacements on passenger side, it now also pulls while braking...hard. The same replacements are on the way for driver's side, but could you offer any suggestions for remedies? Thanks!
Matt E is offline
post #2 of 2 (permalink) Old Jan 29th, 01, 09:48 AM
David Pozzi
davidpozzi's Avatar
Check the idler arm, tie rods, and lower ball joints.
The idler arm can flex up and down and increase toe out under braking and bumps if it moves due to wear.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
