Plugs Fouling - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 6th, 01, 05:25 PM
rogleete
Guest
Posts: n/a
Exclamation
About 3 or 4 of my spark plugs seem to foul just at about 1 month for the past 3 months, I can tell when they go because it will stutter like crazy and have no power. When I pull them to check, I noticed they are covered in oil. Where do you think this oil is coming from and how to fix it? Its not the valve seals is it?
thanks,
'69 Camaros SS 350, red w/ white Z28 striping. .030 over, 9" rear, 3.89 gears, 700r4
post #2 of 7 (permalink) Old Feb 6th, 01, 05:44 PM
valve seals' is the most common resone for this, but ring's can be at falt also. if you have a little blue smoke at start up but that is it most likely valve seal's. if you have blue smoke while running, most pronounced while coasting down after a run, IE like on a freeway off ramp.
ilbl8 is offline
post #3 of 7 (permalink) Old Feb 7th, 01, 04:55 AM
Lightbulb
Make sure your engin is runing at the right temp. Or try some hot spark plugs. Also make sure your not runing with to much oil.
oil pan 4 is offline
post #4 of 7 (permalink) Old Feb 8th, 01, 01:41 AM
Jeff
Change the valve seals...that's cheap to do. Also be sure it's not over filled with oil like the other post said. Someone had a chrome oil pan in my car when I got it, and the dip stick wasn't the proper one, so it always showed low, when in reality it was full.
Ratpack is offline
post #5 of 7 (permalink) Old Feb 8th, 01, 02:42 AM
What plug are you running?
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
post #6 of 7 (permalink) Old Feb 8th, 01, 03:54 PM
rogleete
Guest
Posts: n/a
AC Delco 45tS plugs
post #7 of 7 (permalink) Old Feb 8th, 01, 09:07 PM
If fresh valve seals dont fix it, then get some of them spark plug anti-foulers from your local parts store...you'll go farther between foulings...this will help get you by until you can get the engine rebuilt. How do I know this? My first vehicle ('69 chevy truck) had a totally worn out 307...burned a quart of oil every 65 miles...a real mosquito killer. Turned out the rings were frozen to the pistons.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
[This message has been edited by travis (edited 02-09-2001).]
travis is offline
