Random No Starts - Team Camaro Tech
post #1 of 26 (permalink) Old Aug 11th, 12, 06:54 AM Thread Starter
Angry Random No Starts
I have a 91 Z28, 5.0/5-speed, purchased last fall. As far as I can tell, the only modification significant to starting/running is a MSD ignition module.
Until now, the car has started and ran great, except that 6 months ago I installed a new fuel regulator diaphragm (the old one actually had a hole in it!) and it ran perfectly again after that.
1 month ago all of a sudden it wouldn't start one afternoon at work . Long story short, I've found that it will start 7-10 times in a row, and then for no apparent reason it won't start. I've installed a fuel pressure gauge and have verified that pressure is good (42 to prior to starting even if it fails to start, 35 at idle when it starts, pressure rises with accelerator pressure).
I've been blaming it on bad fuel, and attempted this week to run the fuel out of it. The cars runs perfectly though once started, but on this latest attempt to use up the fuel I found that after some time, it would no longer idle. It ran great as long as the rpm's stayed up above 1500 or so, but if I let it idle it would immediately die.
I also found that while being towed it would start immediately when I let out the clutch in 3rd/4th gear. In fact I was able to get it back home under its own power as long as I kept the rpm up. (that was some tricky clutch/brake/accelerator action) Once in the driveway it had to be pushed into the garage because it would not start again.
Thoughts on this problem please!
eroclese is offline
post #2 of 26 (permalink) Old Aug 11th, 12, 07:47 AM
Re: Random No Starts
I would check all vacuum hoses for cracks and any hose in question, replace it.
The biggest vacuum leak would the EGR valve in the bottom of the manifold. If a bit of carbon/soot is stuck in the needle & seat, vacuum leak. One can test by reaching underneath the diaphram cap and raise the needle through a hole. If engine dies, good EGR valve. If in doubt, replace it and the temperature sensor attached to it.
I would cjhange the fuel filter and add fresh fuel.
I suggest to buy a Haynes manual and read how to extract diagnostic codes stored. Plus the book is worth the expense.
Last swap out would be the module with either an AC/Delco or Standard Parts replacement and don't forget to smear on the heatsink compound. Don't use dielectric grease as it will prevent the transfer of heat from module to dist body.
post #3 of 26 (permalink) Old Aug 11th, 12, 03:12 PM
Steps
We have had a strring of cars thru the workshop lately..all the same sort of thing, some also hesitation and loss of power...
Every one has been the bloody egr.. either as Evereet says above , or has been left longer and he EGR desposits have built up in the inlet manifilds choking the air flow.
A quick check to sort between electrical or fuel....if it starts on 'engine start' (ether) its a fuel and visa versa.
Yes check vaccuum leaks, and also check PVC valve is clean and closes.
Steptoe is offline
post #4 of 26 (permalink) Old Aug 11th, 12, 04:21 PM
Chuck
Find out what is lacking when it won't start, spark or fuel. Should help narrow it down and better than just throwing parts at it, hoping for a fix. Not idleing sounds like a bad IAC valve, if it has one.
Chuck is offline
post #5 of 26 (permalink) Old Aug 11th, 12, 05:06 PM
Kevin
SixtyAte's Avatar
Also check the VATS system. You should have a chip in the key that can cause problems if broken or dirty. Clean with alcohol on a q-tip. Also stick the q-tip into the key slot on the ignition and clean the contacts. The VATS system will disable fuel and spark. If you have a spare key, try that. If not go to a local Locksmith and have then find the Ohms of the chip and make you a new key.
Kev
SixtyAte is offline
post #6 of 26 (permalink) Old Aug 11th, 12, 05:56 PM
Lynn
Going to go out on a limb here. Before I do, here is my disclaimer.
I have never worked on a GM fuel injected car, other than the time I offered to crawl under a Blazer and hit the gas tank to see if the car would start for a poor guy stranded 200 miles from home (it did and knowing that I just jolted his in tank pump on, I told him not to turn it off until he was at home or at a repair shop). Now, I know your pump isn't the problem. I only offer that as my disclaimer.
If your car won't run below about 1500 rpm at certain times, and has trouble starting intermittently, but will still run above 1500, then I would suspect the throttle position sensor (TPS).
Lynn
bilodeaulynn is offline
post #7 of 26 (permalink) Old Aug 11th, 12, 09:11 PM Thread Starter
thanks for all the great ideas. I will check into them more this week. I find myself leaning toward the key problem actually. The steering column is not in perfect shape because someone tried to steal it once per the previous owner. It is quite possible that the contacts in the ignition switch itself are losing contact!
I will be checking the other ideas as well though.
eroclese is offline
post #8 of 26 (permalink) Old Aug 11th, 12, 09:18 PM
Kev
Dumb, simple test (and already suggested) shoot some B12 in the intake while cranking.
Nobody likes simple...
67sc is offline
post #9 of 26 (permalink) Old Aug 12th, 12, 05:33 AM
If you look into the key chip, unplug the steering column connector, insert key into tumbler, and measure the key resistance value at the two thin gauge white wires.
No resistance or intermittent, no VATS satisfaction, no start, or rather, no starter crank over. Tumbler will need replacing, steering wheel will need removal, and proof of ownership and original key at any GM dealership will get you a new tumbler with keys.
post #10 of 26 (permalink) Old Aug 12th, 12, 06:19 AM
Kevin
SixtyAte's Avatar
Everett,
Any VATS key with the ( 1-15 Ohms ) chip can be bought at a local Locksmith and cut for the car. A module can also be purchased there. A pass-key system is the weak link in anti-theft. Just think..they used it first in the 1985 Corvette.
Kev
SixtyAte is offline
post #11 of 26 (permalink) Old Oct 15th, 12, 03:11 PM Thread Starter
Hello all,
Although it seems that I am ignoring any update on this issue, the fact is that there hasn't been much update until now.
I've found a suspicious pile of rust under my distributor cap!
Long story short, I need to know how to remove this retainer. I am pretty sure that this is the original distributor...not only because of the rust but the previous owner was meticulous about saving every little receipt and there was nothing about a distributor in the pile...but this does not look anything like the poorly drawn illustration in my Camaro Service Manual.
Suggestions please?!
I've never tried to post a picture, so if for some reason it is not visible please advise me of that.
eroclese is offline
post #12 of 26 (permalink) Old Oct 15th, 12, 03:15 PM Thread Starter
Seems that the picture was successful, so here are some more that I ran into...well, I guess just one more.
eroclese is offline
post #13 of 26 (permalink) Old Oct 15th, 12, 05:34 PM
Good troubleshooting.
post #14 of 26 (permalink) Old Oct 15th, 12, 06:56 PM Thread Starter
Thanks, but what is the secret to removing that? Can it be done without destroying the retainer?
Can that assembly be lifted as a whole unit off that shaft? I can get under the whole thing with a small gear puller probably but am I going to be sorry I did that because something under there that I still need will be destroyed?
eroclese is offline
post #15 of 26 (permalink) Old Oct 15th, 12, 07:07 PM
There might be a retaining ring to remove with a scribe, then lift out the pickup coil.
Check the pictures at RockAuto for ign pickup coil.
You could always buy the next higher assembly as a last resort.
