Backfiring - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 1st, 01, 07:38 PM Thread Starter
69 Camaro with a 350 and HEI distributor. Car has begun backfiring randomly through the exhaust pipes, even at an idle. It also seems to speed up and slow down on its own at an idle. This has cropped up in the last few days. Is this a distributor problem with the advance or something? I have no idea how old the distributor is or if it has ever had any attention.
Greg69SSRS is offline
post #2 of 6 (permalink) Old Feb 1st, 01, 09:03 PM
oh man, vacuum leak,timing chain,valve adjustment,cap and rotor, plug's, plug wire's...........
where are you at? do you have cold wet weather? if so check for a damp dist. cap.
also check for vacuum leak's just for something to do under the hood.
it could be lot's of stuff a lean A/F can cause this too.
ilbl8 is offline
post #3 of 6 (permalink) Old Feb 2nd, 01, 04:07 AM
I just went through the exact problem your having. I would change out the plugs and wires first. Maybe even the fuel filter. If that doesn't fix your problem, then focus on the distributor.
ssdanny69 is offline
post #4 of 6 (permalink) Old Feb 2nd, 01, 11:17 PM
It may just be water in the fuel...we have been having big problems with that around here since it got cold...enough water in there will definately make it backfire.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #5 of 6 (permalink) Old Feb 3rd, 01, 10:54 AM
Fouled plugs........
80 350/425 is offline
post #6 of 6 (permalink) Old Feb 5th, 01, 04:24 PM
Get some gas deicer and take a look at that distributor.
oil pan 4 is offline
