gear drive noise - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 5th, 02, 04:47 PM Thread Starter
I recently had a short block built for my 69 ss camaro, 350 4 bolt. the guy that put the bottom end together for me used a cloyes quiet drive gear drive. upon starting the engine for break in there was alot of noise coming from the timing chain cover, not your typical gear drive whine. upon removing the cover I do not see any marks where something may be rubbing other than where the idler pins make contact with the cover. upon closer inspection I noticed that with the engine on top dead center( front cylinder drivers side)the mark on tooth on the cam gear is facing up instead of on the bottom lineing up with the mark on the crank gear. the cam gear only goes on one way why on tdc wouldnt the mark be on the bottom.cam is a sig solid. pls help
clayjames is offline
post #2 of 3 (permalink) Old Oct 5th, 02, 05:27 PM
Jody
camcojb's Avatar
Both marks up is TDC#1 so that's correct. They tell you to line the marks up to make sure the cam timing is correct, but what they don't tell you is in that position (top mark down, bottom up) that is TDC #6, not #1. When you turn the engine one full revolution you're at TDC#1 and both dots will be straight up.
If they told you to line them both straight up it would be very easy to have one of them off a tooth.
Jody
MY CAMARO
camcojb is offline
post #3 of 3 (permalink) Old Oct 6th, 02, 04:04 AM Thread Starter
Thank You Jody I appreciate your help and knowledge, Im not the sharpest knife in the drawer !! And I am glad I found this web site. I love 69 Camaros and will really benefit from guys like you while trying to get my ride on the st. Tony
