No Spark - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 27th, 12, 06:50 AM Thread Starter
Dan
No Spark
New cap, rotor, points, condenser, wires and plugs and no spark. Car has not run for 30+ years. Any help?
DDZ28 is offline
post #2 of 4 (permalink) Old Aug 27th, 12, 07:22 AM
Camarodude67
Re: No Spark
What about coil and did you pull the distributer out? You have to gap the points or no spark.
Jeff G.
camarodude67 is online now
post #3 of 4 (permalink) Old Aug 27th, 12, 07:35 AM
Bill
Calpantera's Avatar
What kind of distributor is it? Stock or aftermarket?
Start at the beginning and make sure you are getting power to the coil/distributor. Is the yellow wire from the starter connected and does it have power when cranking? What about the wire from the ignition switch? Does it have power when the switch is on?
Sent from my PC36100 using AutoGuide.com App
Calpantera is offline
post #4 of 4 (permalink) Old Aug 27th, 12, 10:22 PM Thread Starter
Dan
Re: No Spark
Got it to start tonight, thanks. Wrong gap on points.
DDZ28 is offline
