RPMs - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 26th, 01, 04:46 AM Thread Starter
Red face
I have an 86 IROC-Z regular 305 2 barrel, and it is perfect ecept for one thing. Every time the car hits about 4,000 RPM it stalls out. I was thinking that it might be the coil, but I don't know for sure and I am pressed for time right now.
Greg4184 is offline
post #2 of 4 (permalink) Old Nov 26th, 01, 05:20 AM
I'd look for soemthing in the fuel system first...sounds like starvation to me. Check fuel pressure, filter, float level...see if you find anything.
Sleepy-69 is offline
post #3 of 4 (permalink) Old Nov 26th, 01, 09:44 AM
Hey did you think to check the air intake. I had a problem like that with my 67 327 and it was because the air intake was screwed up.
Titan38368 is offline
post #4 of 4 (permalink) Old Nov 26th, 01, 04:08 PM
Do you have catalytic converter(s) on the car. If you do, and that 4000 rpm stall turns into a 3000 rpm stall and so on, it is possible you have a stopped up catalytic converter. Happened to me once.
383tpi is offline
