new cam - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 3rd, 01, 04:43 PM Thread Starter
I RECENTLY INSTALLED A CRANE 274H W/ NEW 1.5 LONG SLOT ROCKERS / NEW CLOYES TIMING SET / INTO MY 70 . THE ENGINE IS NOTHING SPECIAL , ITS A .030 OVER 1976 350 MY PROBLEM IS THAT AFTER I INSTALLED THE ABOVE MENTIONED PARTS I CANT GET THE HYDRAULIC VALVE LASH SET ANYWHERE CLOSE TO ALLOW THE ENGINE TO FIRE.THE TIMING SET IS INSTALLED STRAIGHT UP, TDC #1 HAS BEEN VERIFIED , DISTRIBUTOR SETTING VERIFIED, THE ENGINE HAS BEEN HAND ROLLED OVER SEVERAL TIMES TO SET THE VALVES AND ALL SETS PERFECT, THEN AFTER I SET EVERYTHING ( HAND ROLLING THE ENGINE ON EACH VALVE ) I GO TO ROLL IT OVER AGAIN , THE VALVES HIT THE PISTONS . I HAVE INSTALLED DOZENS OF CAMS AND NEVER ENCOUNTERED THIS. PLEASE HELP
70ram is offline
post #2 of 3 (permalink) Old Apr 4th, 01, 12:52 AM
Please don't yell!!! Turn off your cap lock!
Why do you think the valves are hitting the pistons? That cam only has .450 lift...unless the timing set was installed way off or you are adjusting the valves way too tight, you should have tons of piston-valve clearance. If the valves was hitting the pistons, you wouldnt be able to turn the engine over anyway...it would be bound up. Thats why when it happens on a running engine things break. Maybe you could elaborate a bit more?
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 3 (permalink) Old Apr 4th, 01, 01:58 AM Thread Starter
figured it out , thanks anyway.70 hour work week and 3am install dont mix,enough said.
70ram is offline
