check engine light - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 2nd, 02, 02:12 PM Thread Starter
i replaced o2 sensor how do i reset light it said o2 was bad its a 85 camero 305 8 CYL
[This message has been edited by doug8 (edited 08-03-2002).]
doug8 is offline
post #2 of 3 (permalink) Old Aug 2nd, 02, 02:15 PM
ZZ_430's Avatar
Disconnect battery for 10 seconds or so. Depending on what year it is, you may need to clear the codes with a scanner.
Was it a code 13, 44 or 45?
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 08-02-2002).]
ZZ_430 is offline
post #3 of 3 (permalink) Old Aug 3rd, 02, 01:34 AM
Rick
If it's OBDII, usually the computer will reset itself after 3-5 starting cycles. A cycle is both starting the vehicle and driving it a few miles. This assumes the problem has been corrected.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
