Please help before Friday...A/C question - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 20th, 01, 02:57 PM Thread Starter
Angry
I need help on my a/c can anyone help me? He is a link, as I posted it on the wrong forum I guess. https://www.camaros.net/forum/Forum9/HTML/003589.html
I am getting a moaning sound inside the cab, only when a/c is on. I just replaced the blower motor (located passenger side, under the engine hood against firewall) and didn't help. I also replaced the serp. belt, new tensioner pulley, idler wheel, alt./power steering bracket. The compressor was replaced with dryer in 01/01. Could it be going bad, the compressor??
TIA,
Ron
PS. The sound does go away, when I get on freeway or high speeds, it only makes noise at idle.
'89 Suburban/454tbi/2500/3:42;G80 rear(was factory 3:73;G80)/3 speed/4x2/180* Thermo stat/K&N Airfilter/1qt oil per 800 miles/Second owner
'95 Nissan xe-v6/extra cab/automatic/4x2/Original owner
River Bum is offline
post #2 of 3 (permalink) Old Jun 21st, 01, 02:22 AM
Sounds like you may have an A/C line grounding out on the frame or on some metal somewhere..And it is making a pulsing type noise that is transmitting into the passangers compartment.I run into this alot at work.(buick dealership) I would follow all the lines and make sure that they are clear of everything and not laying up against something.....hope this helps
Cly
Clyoatis is offline
post #3 of 3 (permalink) Old Jun 23rd, 01, 08:23 AM
JohnZ's Avatar
This is called "compressor moan", and was a common complaint in the 60's and early 70's on many Chevys; dealer TSB fix was to add a brace to stiffen the compressor mounting bracket arrangement.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
