Ignition Modual question - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 20th, 02, 10:33 AM Thread Starter
On my 88 2.8 v6 stalls when the motor is warmed up, On cold starts it runs fine....
I was told it was the I-M...Is there any ways to check it to see if its bad?.....thanks
SSupermanZ is offline
post #2 of 4 (permalink) Old Sep 20th, 02, 10:45 AM
ZZ_430's Avatar
Next time it stalls, take a test light....
Near the distributor/firewall area, you will see a white wire sticking out of a harness, and empty connector. This is the tach wire. Probe connector terminal with test light.
When cranking, light should pulse...if it doesn't, it's a bad module... or wiring to the module.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS
67 RS/SS Convertible, 70 RS
[This message has been edited by ZZ430DropTop67RS (edited 09-20-2002).]
ZZ_430 is offline
post #3 of 4 (permalink) Old Sep 20th, 02, 12:56 PM Thread Starter
I'll try that......thanks
post #4 of 4 (permalink) Old Sep 20th, 02, 03:14 PM
ZZ_430's Avatar
I just thought I'd mention the pick-up coil in the distributor could also cause hot stalling.
This might be a good time to just replace the distributor with a rebuilt unit that would already have a new module and pick-up coil.
ZZ_430 is offline
