Help..Carb running too rich - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 23rd, 01, 01:06 PM Thread Starter
Thomas
How do i adjust the air/fuel mixture on my holley 750. I know less than nothing on how to adjust them. i would appreciate any advice.
thanks...
70 1/2 RS Camaro
Slomaro is offline
post #2 of 6 (permalink) Old Mar 24th, 01, 04:56 PM
When is it rich? At Idle? If so, you can adjust the idle mixture screws (the small slotted screws on the side of the carb), by turning in until the engine stumbles and then back out until just the point where it runs smooth. If rich most of the time, I'd probably check float adjustment. Give a better description of the problem if you can, it sure would help.
Mark Perkins
ASE Master Auto/Truck
67 RS Convertible
AUTODR is offline
post #3 of 6 (permalink) Old Mar 25th, 01, 02:04 AM
750 vs ?
the air/fuel screws are on the front metering block,turn in till touching (lightly) seat,turn out 1- 1 1/2 turns.check float adjustment and if you have a electric pump, no more than 7psi fuel pressure.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #4 of 6 (permalink) Old Mar 25th, 01, 06:06 AM Thread Starter
Thomas
Thumbs up
The float levels are good, I'll try adjusting the idle mixture screws today. Yes I am using a electric fuel pump, It is set at 8 psi right now.
70 1/2 RS Camaro
Slomaro is offline
post #5 of 6 (permalink) Old Mar 25th, 01, 06:43 AM
JohnZ's Avatar
8 psi is too much - Holley needle/seats are overpowered over 7psi - you need a pressure regulator (mounted on inner fender or closer to carb) set at 6 to 6-1/2 psi. As indicated above, turn your idle mixture screws lightly in to the seats, back out 1-1/2 turns, and start from there. Set idle rpm (screw on driver's side of linkage), connect vacuum gauge to manifold vacuum source (NOT ported vacuum, as there is none at idle), and adjust idle mixture screws 1/4-turn at a time to get highest steady vacuum reading; work back and forth on each side, make finer adjustments (1/8-turn at a time) once it smooths out, and touch-up idle rpm screw as required to maintain correct idle rpm. When you get highest steady vacuum reading, turn each mixture screw IN 1/8-turn and you're done. All of this assumes you have a relatively mild cam - if you have a radical cam, you will have other problems and the process is different.
You didn't say what engine combo or mods you have, if any; if it's basically stock, the 750 is way too much carb for it and you'll have poor off-idle driveability and fuel economy due to low air velocity and poor vacuum signal for metering. A 600 or 650 would be a much better choice for all-around driveability and performance; "Bigger is Better" works fine for horseshoes and hand grenades, but NOT for carburetors. 90% of the street driveability problems I get asked to look at are a result of way too much carburetion and/or too much fuel pressure - race cars are one thing, street cars are another. Speed shops LOVE to sell big carburetors and electric fuel pumps, but they don't work worth a hoot on basically stock street engines.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #6 of 6 (permalink) Old Mar 25th, 01, 10:48 AM Thread Starter
Thomas
Here is my engine combo
350, 30 over
10.5:1 compression pistons
292/292 duration cam with .500 lift
441 heads with 2.02-1.60 valves
Victor Jr intake
half inch nitrous plate, jetted for 100 hp
3500 stall convertor/ th350 trans
373 rear gearing
I do have a pressure regulator, because of the nitrous.
70 1/2 RS Camaro
Slomaro is offline
