heater help - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 30th, 99, 01:15 PM Thread Starter
my heater works, but it wont change speeds. I have replaced the heater control switch and i have run new wires from the battery to the new switch. but no luck. if anyone has any info about heaters please help. thanks
igottacamaro is offline
post #2 of 6 (permalink) Old Dec 30th, 99, 05:59 PM
what year is your camaro?
josh
josh_sallee is offline
post #3 of 6 (permalink) Old Dec 31st, 99, 05:17 AM
CD
check your heater motor sometimes 1 speed burns out
69 z/28 clone
72 z/28 #s matching
CD is offline
post #4 of 6 (permalink) Old Jan 1st, 00, 11:35 AM
the blower motor itself does not have different speeds. there is a blower resistor that reduces voltage to the motor, if you have a first gen camaro, it should be located on top the heater box behind the glove box hope this helps.
67FREAK is offline
post #5 of 6 (permalink) Old Jan 2nd, 00, 05:46 PM
Just a little more on the resistor, it will have three wire connections, it is bolted to the heater box by two screws, when you unbolt it it looks like a couple of springs, some cars have the resistor on the engine side of the heater box, clean these connections first
should work.
Rob.Canada is offline
post #6 of 6 (permalink) Old Jan 4th, 00, 07:24 PM
I know exactly what you need to do. My 67 Camaro was the same way when I bought it. Upon investigation, I noticed there was no resistor on the top of the heater box behind the glove compartment. Check to see if you have one there. Hope this helps
jrt67ss350 is offline
