2001 Camaro Radiator Fans not Turning On.. - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 10th, 12, 12:00 PM Thread Starter
Mark Patterson
Angry 2001 Camaro Radiator Fans not Turning On..
I have a 2001 with a 3.8 and Std Trans.
I'm having issues with over heating, due to the Fans not coming on. I know the fans are good, because i jumped the relays and the fans power on.. also I can turn the A/C on and a fan will come on.. I have moved the relays around and am pretty sure they are all good. not sure what to check next.
Is there a way to check the relays, or are they just a replace item (if unsure)
How can i test the water temp unit?
also my temp gauge seems to stop at 210... no matter if the fans come on or not.. I can smell, and hear it overheating but the gauge says 210.. could this be the issue? the fans not being triggered...
One last side not.. the head gasket had blown.. i had the heads reworked, and i replaced the gaskets, and thermostat...
Any ideas?
051089
annex_225 is offline
post #2 of 2 (permalink) Old Sep 10th, 12, 01:11 PM
Vintage 68's Avatar
Wink Re: 2001 Camaro Radiator Fans not Turning On..
Unplug the connector at the water temp sensor - if the sensor is bad the fans should then come on.
Then replace the sensor ...
And buy the sensor from GM - cheapo chain 'Auto' store sensors are junk and will fail very quickly
And thanks for only posting in one forum as stated from now on
1968 Convertible
Some trucks
Vintage 68 is offline
