Driveline Vibration - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 19th, 12, 07:27 PM Thread Starter
Driveline Vibration
First a little history: I've owned this 68 Camaro for 25 years. For most of it, I've had a vibration above 55 mph. Don't remember when it started. It starts at 55mph and comes and goes. The car was originally a 6 cyl p/g. The vibration is still there after the following:
- changed engine to 327V8 everything new in subframe (body mounts, front suspension, motor mounts etc.)
- rebuilt rear diff - new everything including changing gears from 2:73 to 3:36 new bushings, bolts, nuts, shackles but original springs
- Balanced original driveshaft (added 1.25 oz. I think)
- new trans mount (original was shot, but I think the vibration ruined the mount, not the ruined mount caused the vibration)
- wheels & tires were spin-balanced & static balanced
- pinion angles look good - checked with angle finder - trans & diff at approx. 87*
Flex plate, torque converter, and trans are original. I have some play between the trans and the driveshaft and the seal seems to be leaking (spraying trans fluid on the tunnel)
I suspect the tailstock bushing/driveshaft yolk or flex plate/torque converter, anyone got any advice?
Thanks, Steve
canadian68coupe is offline
post #2 of 4 (permalink) Old Sep 19th, 12, 08:19 PM
wayne
Re: Driveline Vibration
know anyone with a set of rims/tires that you can borrow for a short drive?
I had a set of cragars on my 68 that the stud holes had worn and I could not get a balance to work at both low and high speeds. It was one or the other. Changing the rims solved the issue
2x1968muscle is offline
post #3 of 4 (permalink) Old Sep 19th, 12, 08:58 PM
Matt
Have you check you u-joint angles? If they are too far out of spec you can get a vibration.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #4 of 4 (permalink) Old Sep 19th, 12, 09:17 PM
Steps
Going on from Waynes comments
If have after market rims, and drums, check that a rim is not sitting on slightly on one of the balance tags on the drum...
Check the balance tag is on the drum
And no paint between the rim and steel of the drum where it bolts up.
If have sloted rims ... use orginal tapered end stud bolts , tighten each a litle by little by hand with a slight knick up so the holes center on the bolt tapers... then remove each one , 1 ata time and replaced , torque up with the correct matching to rim bolts and washes.
If cragers , use the correct carger washers and bolts.
oops 1st question is the vibration in the steering wheel , or feel it in your feet or in the base /back of the seat?,, that will tell if front suspection or rear.
If not in the steering wheel yes those are a good possilty...u meantioned new engine. So did these get replaced or still orginal?
Do they still have their balancing tags on them....I assume thenew engine was not dynamically balance from the harmonic balancer bolt thru to the flex and torque convertor....
driveshaft yolk
Bit confused here.. u got the new Driveshaft balanced...that should have bee done with the new yoke and the universal joints all together?????
Steptoe is offline
