TBI injecter problems - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 11th, 01, 06:11 PM Thread Starter
Ya, i was wondering if anyone knew how to tell if your injecters were out on a TBI? i have a 89 305 and the injectors aren't spraying but they are gettin fire to them. could it be in the ecm?
bolonypony182 is offline
post #2 of 4 (permalink) Old Feb 11th, 01, 08:02 PM
Dale
Your injectors are firing? How do you know? They are ground controlled,should have 12 volts to them,with key on.Whats your fuel pressure?Needs 12#s of fuel pressure.Can you hear your fuel pump run(for 2 seconds) when the key is in run?
68 z28 68 rs 327 73 454 vette
dale68z is offline
post #3 of 4 (permalink) Old Feb 12th, 01, 04:36 PM Thread Starter
i know its gettin fire because i checked the wires on the injectors with the key on. fuel has been a concern, but i know its getting fuel and i can hear the fuel pump run. does it have to have 12#s of pressure just the work the injectors? or could it be a peice of trash in the TBI? anyhow, i am getting a kit for it and cleaning the TBI.
post #4 of 4 (permalink) Old Feb 12th, 01, 07:35 PM
Dale
With the key on you WILL have 12v, When cranking,there will be a toggling ground at injector,every time injector gets a ground,it fires.Check your fuel pressure,my experience is the injectors dont go bad very often.Fuel pumps are real weak,I replace 2 a week at my shop.PLEASE,check the fuel press.first.Will it start on carb cleaner?
dale68z is offline
