69 front directional/parking lights - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 9th, 02, 09:24 AM Thread Starter
I have been having a problem with the front directionals on my 69 SS. Specifically, my directionals and 4-ways work when the head lights and parking light are not on, when turned on the front directionals and 4-ways do not work they stay on constantly - no breaks. The rear works as it should. I have replaced the flasher, lamps in both units, and the head light switch. Using a test light I have found that from the harness GM connector, where the parking light assemblies plug into works fine on both sides. So I am thinking a ground with in the parking light assemblies themselves???
Any thoughts???
502maro is offline
post #2 of 5 (permalink) Old Apr 9th, 02, 10:01 AM
Vintage 68's Avatar
I believe you are on the right path with the ground (or lack of same) theory, I recently ran into this on another vehicle.
I ran a temporary ground to the bases using jumper wires with aligator clips and the signals worked normally. I then cleaned all the base connections and ran a small wire to the chassis from the rad. support in an area you can not see from above (to maintain that "stock" look). The owner thought the headlights were brighter after I finished also.
Vintage 68 is offline
post #3 of 5 (permalink) Old Apr 10th, 02, 03:37 AM
It would be suggested that you post your question in only one forum, When you post the same question in different forums, some one may duplicate an answer.
As well if you choose the forum that fits your question you are bound to get an expert answer.
As an example the performance forum does not interest me I go there last if time permits, I enjoy the electric and trouble shooting forums, and usally start with them.
I see that this is one of your first post at this forum, and this is only some helpful hints for the future.
Rob
Rob.Canada is offline
post #4 of 5 (permalink) Old Apr 10th, 02, 04:09 AM
I had a similar problem when I first got my car. Its a 69 and the front park/turn signal lamp housings were not tight (loose nuts to the body) and since the ground is provided through the housing, the turn signals and flashers acted wierd. Also check to see if you have 2 flashers. Mine does 1 at the fuse block and 1 in a holder under the dash. Good luck.
Black 69 camaro
[This message has been edited by HOTROD69CAMARO (edited 04-10-2002).]
HOTROD69CAMARO is offline
post #5 of 5 (permalink) Old Apr 10th, 02, 08:33 AM Thread Starter
Thanks to all for the ideas. I played with it some more last night, found out that the wires which go to the GM style factory connector that come off the wire harness are loose. Since this is a 3 wire from the harness into the socket and 2 wire plug to the parking lamp (both lamp wires are hot, one is for light the other directional/flasher 4-ways) there is no way to cut the clip out. or is there an easier fix???
Also..Sorry for the multi posts, I am a new member. I realized after posting on "electrical" that this is really a trouble shooting question...I did not know how to erase the other. :0
502maro is offline
