Running hot - Team Camaro Tech
post #1 of 31 (permalink) Old Apr 19th, 00, 04:15 AM Thread Starter
I have a 1992 RS with a stock 305 V8. I have flushed then re-cored the radiator, replaced the thermostat, replaced the lower radiator hose, replaced the heater core, replaced all heater hoses, checked the fan, and replaced the water pump. It still runs hot. Any ideas what to check next?
lori is offline
post #2 of 31 (permalink) Old Apr 19th, 00, 04:28 AM
Have your timing checked. KZ
kz1000ltd is offline
post #3 of 31 (permalink) Old Apr 19th, 00, 06:27 AM
Dee
<BLOCKQUOTE>quote:</font><HR>Originally posted by lori:
I have a 1992 RS with a stock 305 V8. I have flushed then re-cored the radiator, replaced the thermostat, replaced the lower radiator hose, replaced the heater core, replaced all heater hoses, checked the fan, and replaced the water pump. It still runs hot. Any ideas what to check next?<HR></BLOCKQUOTE>
Dee is offline
post #4 of 31 (permalink) Old Apr 19th, 00, 06:31 AM
Dee
<BLOCKQUOTE>quote:</font><HR>Originally posted by Dee:
<HR></BLOCKQUOTE>
Have a manual fan installed as in mine the fan is working but doesn"t run enough to keep the engine cool.This way you can turn it on when you see the temperature gauge climbing!
Apparently nothing wrong in my car either but it still overheats especially when idling for a very short time.So after checking all the same parts you did and changing them all this worked! Goood Luck
Dee is offline
post #5 of 31 (permalink) Old Apr 19th, 00, 06:49 AM Thread Starter
Here's the thing! It overheats only when the car is moving! If it sits idle, it won't overheat. It hardly even runs hot when it's idle - maybe ten to fifteen degrees more than normal.
lori is offline
post #6 of 31 (permalink) Old Apr 19th, 00, 07:06 AM
Cool
Hi Lori.
Here is my dumb question for the day. Have you taken it to the dealer to compare actual temperature to what the guage is reading. I have had several in the past (92s) that were reading incorrectly by 10-15 degrees.
67 SS
70 Z/28
camaroguy is offline
post #7 of 31 (permalink) Old Apr 19th, 00, 08:41 AM Thread Starter
No, I haven't taken it to the dealer to verify the actual temperature. But, that's because if the water in the reserve tank is boiling, it has to be too hot! It only overheats when I drive over 45 mph when the outside temperature is 85+ degrees. It never overheats when it is idle.
lori is offline
post #8 of 31 (permalink) Old Apr 19th, 00, 11:02 AM
Cool
It just dawned on me. Is your air dam missing underneath? This will be the problem if it is missing. Usually everyone scrapes this off on a curb, I have done that before.
It diverts the air up into the radiator. When your traveling at speed, no air will get in.
67 SS
70 Z/28
post #9 of 31 (permalink) Old Apr 19th, 00, 12:02 PM
Cool
Guy you have a good point there but, I'm a gonna ask another dumb question. Did ya change the radiator cap when you changed everything else ?
71 Camairo
[This message has been edited by 71 Camairo (edited 04-19-2000).]
71 Camairo is offline
post #10 of 31 (permalink) Old Apr 20th, 00, 04:35 AM Thread Starter
I thought of the air dam, too. I had taken mine off due to some damage. I replaced it soon after I started having these overheating problems. Even after replacing the air dam, it is still running hot. And, yes, I did replace the radiator cap when I had the radiator re-cored. What are the chances that a water jacket is clogged? This is certainly not my area of expertise! So, I don't even know if that is a logical question. And, to add further to the discussion, running the AC makes it overheat much faster. Running with the heater as high as it will go helps to a certain degree. But, that is not a viable solution for the hot, humid summers here in the south!
lori is offline
post #11 of 31 (permalink) Old Apr 20th, 00, 08:48 AM
Cool
The only other suggestion is to do what KZ suggested and have your timing checked.
71 Camairo
post #12 of 31 (permalink) Old Apr 20th, 00, 11:09 AM
Lonnie
Is that an electric fan or does it have a fan clutch? The clutches go bad.
67 410sb 11.63 @117.6
Lonnie67 is offline
post #13 of 31 (permalink) Old Apr 20th, 00, 01:16 PM
mccorry's Avatar
Yes Lonnie...but if it were the fan clutch...it would REALLY overheat at idle.
I would agree that you should have the timing checked. Does the motor "knock" or "ping"?
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my car ---&gt; www.mindspring.com/~mccorry
mccorry is offline
post #14 of 31 (permalink) Old Apr 20th, 00, 06:27 PM
David Pozzi
davidpozzi's Avatar
Is the fan running the right way, pulling the air thru the radiator? It's just a DC motor, if the wires got reversed....
Got the right water pump for your serpentine belt system" I think some of the systems run the water pump backwards and take a different impeller. I think it's just the vette system.
davidpozzi is offline
post #15 of 31 (permalink) Old Apr 21st, 00, 03:10 AM Thread Starter
The fan is electric. It checked out OK. It's pulling air in the right direction. I have considered adding a toggle switch to it just so that I can turn it on at all times if I so choose. But, the only benefit I see in that is that it would help to keep the car cool when it's idling. It doesn't make much sense to me to do that since the car doesn't actually overheat until the car is moving at a higher rate of speed in warmer weather. It runs a little warm when idling, but nowhere near the point of overheating.
The water pump is the right one. Actually, I think the one that I had on there to begin with was still good. I was just concerned that it might not be pumping enough water to the motor. So, I replaced it since it was a fairly simple task.
lori is offline
