No Power From Motor - Team Camaro Tech
post #1 of 7 (permalink) Old May 14th, 01, 03:43 PM Thread Starter
I just rebuilt my 350. I put a edelbrock cam performer RPM intake and edelbrock 650 carb and edelbrock valve springs that match the cam along with a edelbrock double roller timing chain. The car has no power at all.Anyone have any clue or ideas on why it has no power?
74Camaroguy is offline
post #2 of 7 (permalink) Old May 14th, 01, 04:13 PM
What heads and which cam? I have the RPM package and my car runs like a champ and has more throttle response and power than I expected plus my power brakes work great too.
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
CA420 is offline
post #3 of 7 (permalink) Old May 14th, 01, 05:10 PM
Talking
what do you mean by no power?
the mechanic is offline
post #4 of 7 (permalink) Old May 16th, 01, 09:07 AM
check your vacuum.
Sounds like your manifold is leaking.
Pull your air filter and snuff the carb the engine should die if not you have an intake leak.
Stock 67 327 RS
www.angelfire.com/ca7/goatjjcamarors/gm
goatjj is offline
post #5 of 7 (permalink) Old May 16th, 01, 09:24 AM
You may have the cam 180 off. It will run but no power
TIM
Tim Meredith is offline
post #6 of 7 (permalink) Old May 17th, 01, 07:32 AM
My guess would be the RPM cam. That cam really blows. Mine was a pig until high RPM's. With an automatic and a stall, it might not be so bad, but with a standard, the motor was useless. The RPM setup is good, but there are much better cams.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #7 of 7 (permalink) Old May 17th, 01, 09:18 AM
Wink
street: SMALLER IS BETTER! this applies for 90% of the hot rodders out there who tinker. if know more than the average home mechanic you can toss out this idea(partialy). for the street in your car i would have gone no bigger than 218 duration and probably smaller around 212 degrees. this would have made a very fun to drive vehical,sure it may not have sounded COOL but it would pull hard!
if thats the stock motor(asuming it a 74) it has low compression and works better with smaller cams.
sldhd is offline
