69 eletrical - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 1st, 04, 01:52 PM Thread Starter
ok, I have a problem with my 1969 Camaro. It will not turn over, and the headlights will not turn on, though the dash lights, and dome light do come on. What should I check, and how do I check it/fix it? I know almost nothing about it, so I'll need in depth guidance. Thanks.
Revolver is offline
post #2 of 3 (permalink) Old Mar 2nd, 04, 08:59 AM
Headlight problem usually points to the passenger fender ground not hooked up or having a bad connection. Make sure you have a good solid connection from the ground on the battery to the hookup on the passenger fender.
and
Brian Lewis is offline
post #3 of 3 (permalink) Old Mar 2nd, 04, 09:04 AM
Sounds like a dead battery to me. Clean or replace the battery cable ends and charge up the battery. [img]graemlins/thumbsup.gif[/img]
BPOS is offline
