Car intermit dies at idle and take off and more - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 15th, 01, 03:55 AM Thread Starter
I have 89 Camero 2.8 inj. It sometime dies when fan comes on and backfires thru exaust. Hooked up aux switch to fan. But does the same thing. Shop can't fix it. After 3 trys and $ later. If i turn on the AC, it does the same thing. Usually does it when temp is 220. It also effects the idle speed when this happens. It will restart right away. And sometimes pumping the gas will pull it out of the situation. HELP
Chuck89 is offline
post #2 of 4 (permalink) Old Oct 15th, 01, 04:26 PM
did the shop pull any codes? it sounds like a ecm problem.
chris
1980 Z/28
350 .60 over stock bottom end world products torker2s 280H compcam edel.performer rpm,holly 750 dual feed.
2200 stall,- but still not done.
the mechanic is offline
post #3 of 4 (permalink) Old Oct 15th, 01, 05:15 PM
Unhappy
This is far fetched, but it almost sounds like the fan is using so much current there isnt enough to operate the ECU system and/or the igition system.
cavemate is offline
post #4 of 4 (permalink) Old Oct 15th, 01, 06:20 PM
Lightbulb
Just an idea! But is your alt. putting out enough amps, battery cables tight & clean,battery holding a full charge?
Branded is offline
