help me please !!!!! - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 11th, 01, 09:13 PM Thread Starter
Exclamation
I have a 93' pontiac grand am gt 3.3L V6
my problem is that ill drive for a good five min around 5 miles. then i come to a stop light and the damn thing clutters and shkes spits and spudders then dies.....the car will restart but when i put it back in drive or reverse it dies and will not go ?
I replaced the fuel filter and im clueless the problem is in about ten hours this car has to drive me 1900 miles !!!!!
some say that it is the fuel pump but it doesnt make any noise or when it is idling it regulates...also when i put the car in park the idle fluckuates for a few sec's then regulates??????
Guys im desprite to find an answer please help me..
jmsmcgrt is offline
post #2 of 7 (permalink) Old Jan 12th, 01, 04:44 AM
Wink
had a similiar problem with my Grand Am, it turned out to be the torque converter clutch solinoid.
http://www.geocities.com/d_depaolo/
dan1205 is offline
post #3 of 7 (permalink) Old Jan 12th, 01, 04:47 AM
Jody
camcojb's Avatar
You need to get it to a shop and have them hook a scan tool to it and see what's wrong. It can get expensive just replacing parts. That's the advantage of the computer's; they'll tell you what's wrong (as long as you have the correct tools to read them.
If I had to guess, I'd say change the O2 sensor. Since it runs fine cold and the O2 only is used once it gets up to temp (doesn't use it when cold), it makes sense. If the O2 sensor is bad it affects warm driving only, both idling and cruising (would be worse idling probably).
Jody
camcojb is offline
post #4 of 7 (permalink) Old Jan 12th, 01, 05:04 PM
mccorry's Avatar
It does sound like the torque converter lockup solenoid has siezed.
If you are standing at the front of the car...you will see a harness that plugs into the front of the tranny housing. It is a squarish type plug with 4 connectors. If you can get the solenoid to release...unplugging this harness will keep the converter lockup from re-locking.
mccorry is offline
post #5 of 7 (permalink) Old Jan 13th, 01, 01:18 PM
Freddie
May be the EGR sticking open. Is the "check engine" light comming on? If it is you will have at least one code in the computer. Have someone check for codes.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #6 of 7 (permalink) Old Jan 14th, 01, 04:42 AM
I would definately check out that torque convertor lockup switch...a co-worker just bought a well used chevy cavalier and when he was doing a tune up on it, he found the harness unplugged from the trans...he plugged it back in and started having the same problems you describe (drove normally before the harness was plugged in). If unplugging it fixes the driveabilty problems, then get it replaced, otherwise you risk burning up the trans due to excessive high gear torque convertor slippage.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #7 of 7 (permalink) Old Jan 16th, 01, 04:15 PM
the tcc problem that the trans has will only
be if your car is a 3 speed(125c). 4 speeds
operate a bit different.
drews70camaro is offline
