1987 2.8 MPFI CAMARO HELP!! 2000 -3000 RMP IDLE - Team Camaro Tech
post #1 of 2 (permalink) Old May 29th, 99, 08:37 PM Thread Starter
My 2.8 MPFI has an idle of 2000 RPM'S + in park . I was told i have a massive vacuum leak , but they could not find it? The ECM code is 32 EGR failure .The car shakes and moves around at low idle . Could it be a leaking intake manifold gasket? I was able to cross the MAF sencor wires , ground to signal.this droped the idle to 500 + 950 rpm.
But just a temp fix i got a ECM code 34 MAF/MAP sencor too low. No other codes but them. Please help
[This message has been edited by BIGMAN (edited 05-29-99).]
BIGMAN is offline
post #2 of 2 (permalink) Old Jun 8th, 99, 09:15 PM Thread Starter
i repaired the car my intake manifold gasket had blown up into the valve cover makeing the car take air from the valve cover and bottom of the motor i have a normal idle now
BIGMAN is offline
