starter hangs engaged - Team Camaro Tech
post #1 of 18 (permalink) Old Jan 4th, 02, 07:53 AM Thread Starter
Angry
I have 68 camaro with 454 motor[early 70s].When it has not been started for a day or 2,the starter engages and will not disengage!I have put new starter solenoid on but it still happens! After the car starts, it works fine. Could the ignition switch be hanging? Any help would be a huge help!!
CVH-SS/RS is offline
post #2 of 18 (permalink) Old Jan 4th, 02, 08:51 AM
Unhappy
CVH,
I'm experiencing the same problem. Starter keeps cranking even when the key is removed. I've replaced the solenoid and some brittle wires leading to it, and the starter switch but it still happens. It disengages fine when the engine starts.
I'm thinking its a short, fried inline relay or improper grounding in the wire harness from the horn relay through the firewall to the starter switch. Also could be a bad horn relay. Anyone else have this problem?
Robert.
68 Base Coupe, 327/210hp with TH400
99 Silverado
Lownf4me is offline
post #3 of 18 (permalink) Old Jan 4th, 02, 11:16 AM
probaly the ignition switch going bad and/or out of adjustment.or maybe you have some funky wiring problem. or the car is possessed..
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #4 of 18 (permalink) Old Jan 4th, 02, 07:28 PM
XK1
I had a car that did this with a new starter. Another starter solved the problem. The contacts in the solenoid were sticking.
76 Camaro/mild 350 .030/M21/Z28 body parts/lotsa other goodies
XK1 is offline
post #5 of 18 (permalink) Old Jan 5th, 02, 12:46 AM
Bruno
Lightbulb
Some times the starter get stuck against the flywheel cause it's in need of shims. Some resto catalogs sell them.
Good luck...
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
ORENCH is offline
post #6 of 18 (permalink) Old Jan 5th, 02, 03:57 PM
Put car on jack stands parking brake on 9/16 socket an extension, crawl under, have someone start engine if stays engaged loosen bolts that hold starter, if disengages try putting in some shims.
clash69 is offline
post #7 of 18 (permalink) Old Jan 8th, 02, 08:08 AM
ORENCH and Clash69,
The problem posted describes an electrical problem, not mechanical as in needing shims. Are you suggesting that an improperly shimmed starter could cause a starter to continue cranking even after the key is turned off and removed?
Just asking, no flames here.
Robert.
99 Silverado
Lownf4me is offline
post #8 of 18 (permalink) Old Jan 8th, 02, 08:43 AM
Send a message via AIM to Spames
Not my reply, but yeah, it could. If the starter gear and flywheel mesh too hard, it might stick. Metal expands when it's cold (right?), as he said it is fine after the car warms up. It would seem me that it's possible that various parts contract enough after it warms up to make everything give a little. In my experience though, if the starter is not shimmed properly, it can sound really harsh while it's cranking.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #9 of 18 (permalink) Old Jan 8th, 02, 10:18 AM
Talking
Not to be a wise a$$ but metal expands when hot and contracs when cold
Branded is offline
post #10 of 18 (permalink) Old Jan 8th, 02, 10:42 AM
I had a jeep once, that was acting real wierd. Even with the key removed, the starter stayed engaged, the problem was fixed with a full battery charge??
any idea why??
68ragtop is offline
post #11 of 18 (permalink) Old Jan 8th, 02, 10:49 AM
Mr.C-
I knew it was one way or the other. No offense taken, just trying to throw out some ideas, so somebody doesn't throw all sorts of money at something that could be possibly fixed with some $2 shims.
Spames is offline
post #12 of 18 (permalink) Old Jan 8th, 02, 11:12 AM
Talking
Spame I understand and agree 100%
Branded is offline
post #13 of 18 (permalink) Old Jan 8th, 02, 03:16 PM
Bruno
Wink
Sorry "Lownf4me" but I was answering to CVH-SS/RS situation where he didn't mentioned the removed key.
CVH-SS/RS
posted 01-04-2002 10:53 AM
Just trying to help a little...
[This message has been edited by ORENCH (edited 01-09-2002).]
ORENCH is offline
post #14 of 18 (permalink) Old Jan 12th, 02, 06:34 PM Thread Starter
Unhappy
Thanks for all the help. The starter does keep cranking even when the key is removed.The previous owner wired the tach lite to the ignition wire{hot from switch} so the lite would be on whenever the car is on. Could this be part of the problem? This is also why i think the ignition switch is working because when I turn off the key, the tach lite goes out but the starter keeps cranking.The starter only hangs the first time and of course the car doesnt start until it finally disengages and I try again.Then the car starts and works fine the rest of the day???????
post #15 of 18 (permalink) Old Jan 31st, 02, 07:07 AM
CVH,
Well I've diagnosed my starter problem. I replaced the fried horn relay but the problem persisted. So I removed the starter and hooked the wires up to it outside the car. It operates fine, so the problem must be improper shimming.
I took the back plate off the starter to inspect the brushes - man I'm surprised that thing even turned with all the oil and crap that was inside. So I'm swapping out the starter too.
So if you're still having a starter run-on problem and have ruled out electrical problems like I have, it's got to be a shimming problem.
Hope this helps,
Robert.
99 Silverado
Lownf4me is offline
