wheretiming - Team Camaro Tech
post #1 of 19 (permalink) Old Nov 1st, 01, 03:31 PM Thread Starter
i have a 427 60 over 13-1compression crank cut 20 and 20 with a windage tray, merlin rectangle port heads 219 188 valves, 119cc combustion chambers, weinand team g intake 750 holley double pumper mechanical secondaries, headers, underdrive pulleys, eldebrock geardrive retarded 4 degrees, msd 6a ignition, msd blaster 3 coil, mallory unilite distributor vacuum advance, 11mm wires non resistor plugs, 400 shot of nitrous and a jacobson mastermind computer, i dont know where to set the timing without even using the nitrous, it has a muncy 4spd and 456 gears and it is my street car so it has to start everytime. please help
websurfingbitch is offline
post #2 of 19 (permalink) Old Nov 1st, 01, 03:34 PM Thread Starter
i almost forgot the most important part the cam is a crane with 264 269 [email protected] and a 560 580 inch lift with a 114 lobe separation
post #3 of 19 (permalink) Old Nov 1st, 01, 05:10 PM
DjD
DjD's Avatar
Did you just build this or have it built? I wouldn't know where to begin with a mill like this on the street. Sounds like a bit much for a daily driver. What will you be putting in the tank? I'd say seek the builders advice...
DjD is offline
post #4 of 19 (permalink) Old Nov 2nd, 01, 12:53 AM
Cool
I agree with DJD, a bit much for the street, but a serious grocery-getter!
Definitely ask the builder on what timing to run.
If I had to guess, I'd start at 8 deg BTDC and tune for total timing of say 26-30, compression going to kill ya, however, l/s will help some to bleed off pressure.
If one has a problem starting hot, a friend of mine rigged up a push-button switch cutting out (opening) ign until starter had the engine spinning fast enough, then let go of switch, started right up. Worked every time.
I'd like to see the radiator for this bad boy, this car IS going to generate some heat.
I hope you didn't forget the roller lifters, rockers, and rev-kit.
Let us know how it runs after break-in? Yeah,right.
post #5 of 19 (permalink) Old Nov 2nd, 01, 03:29 PM Thread Starter
number one, i run straight airplane fuel ererytime it needs to be filled, the cam is a solid lifter cam with roller rockers, next it has a milodon high volume water pump, flexfan, electricfan and a three core racing radiator never goes over 230 which is pretty good. I have the engine broken in, the timing was set by an old hippie that messed with race cars and the car ran great but i plucked it out of my ss and put it in a malibu took out the distributor so it wouldnt get smashed and cant find the hippie anymore. cranking isnt a problem i have a 15-1 compression starter. and i built the engine just had someone machine everything.
post #6 of 19 (permalink) Old Nov 2nd, 01, 04:16 PM
JohnZ's Avatar
Gee, neat street setup - here's mine, when I had it out for detailing last week - I built it, but didn't do the machine work:
...and I know how to set the timing - maybe you should place an ad for an old hippie
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #7 of 19 (permalink) Old Nov 2nd, 01, 04:44 PM
ZZ_430's Avatar
Cool
Now THAT'S an engine!
What does that power?
Don~ ZZ430DropTop
~~~~and~~~~
Pro-Touring.com DropTop
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #8 of 19 (permalink) Old Nov 2nd, 01, 04:56 PM
Seems to me someone was smoking while surfing.
tracyracy is offline
post #9 of 19 (permalink) Old Nov 3rd, 01, 12:20 PM
JohnZ's Avatar
Wink
Isn't it amazing what some people want you to believe? If you had a .020"/.020" crank would you advertise it? Maybe he thinks it's like a "30-30" cam
Engine in the pic is a new Mercedes-MTU 12,500hp twin-turbo V-20 diesel with 16,500 ft-lbs. of torque; 18 feet long, made for locomotives and ships. How'd ya like to shine 20 valve covers every week?
JohnZ
JohnZ is offline
post #10 of 19 (permalink) Old Nov 3rd, 01, 02:27 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by JohnZ:
<HR></BLOCKQUOTE>
well then if your so smart YEAH RIGHT answer the question where should it be set i know for every 100 shot of nitrous retard 4 degrees and a starting point for a 427 is 8 btdc but i dont know how much to retard for compression.
post #11 of 19 (permalink) Old Nov 4th, 01, 09:55 AM
JohnZ's Avatar
With .060"-over, 13:1 compression, a 20-20 crank, and a 400 nitrous shot, I'd stand well back out of the way of the flying rods and counterweights!
Seems to me that with that kind of setup you'd use a timing retard box that only backed out the timing when the solenoids opened up (hopefully in stages); if you back it out of initial, it'll be a retarded slug during the 99.9% of the time it's just on the motor.
JohnZ
JohnZ is offline
post #12 of 19 (permalink) Old Nov 4th, 01, 11:03 AM Thread Starter
i do have a jocobs nitrous mastermind computer to control the nitrous retard.. and if you use nitrous the right way your rods wont go anywhere duh!!!! anyone knows to safely use nos you need good high octane fuel, the right amount of retard and special set of pistons and rods with a studded bottom end.
post #13 of 19 (permalink) Old Nov 4th, 01, 11:21 AM
Jody
camcojb's Avatar
The rods, crank, block, etc still have to handle that much horsepower and what other people are trying to point out is that you have several weak links in that engine which will probably fail as soon as you start using the nitrous. In addition, if the car hooks at all you'll break that Muncie.
I ran 20 degrees initial and 38 total in a 13-1 468 with 100 octane unleaded. Felt lazy with less timing.
Jody
camcojb is offline
post #14 of 19 (permalink) Old Nov 4th, 01, 02:37 PM Thread Starter
o well it will only be the forth muncy that i crushed behind the engine, the engine builder took care of the crank, rods, and pistons to handle the nos
post #15 of 19 (permalink) Old Nov 5th, 01, 02:33 PM
JohnZ's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by websurfingbitch:
i built the engine just had someone machine everything. <HR></BLOCKQUOTE>
"the engine builder took care of the crank, rods, and pistons to handle the nos"
This is like a quiz show - for one million piston rings, who built this street engine:
a. An engine builder
b. websurfingbitch
c. An old hippie
d. The Tooth Fairy
Your "Lifeline" is anyone in the audience who knows how to set the timing on a 900-hp street engine (or who can find the old hippie racer with the secret formula).
Amazing
JohnZ
JohnZ is offline
