4 cylyder ? - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 6th, 01, 03:35 AM Thread Starter
i know this aint a muscle car ? but has any ever change a coil pack on a 88 cvevy cavaler ? oh my god its back behind the block around heater hose's dip stick u name it , its aroujnd that area hoe in the hell do you get to it , thx help before i get my wood maul, later eric
eric39 is offline
post #2 of 9 (permalink) Old Mar 6th, 01, 05:12 AM
It's easy to get to if you pull the intake manifold but it's hard to get the intake off without pulling the head....Does that help?
Geezer
Geezer is offline
post #3 of 9 (permalink) Old Mar 6th, 01, 12:56 PM Thread Starter
sounds like a ton of work , got too be a trick some how , my pack has two leads sticking out post i mean , i see all of my spark plug wires from top but were do they connect too is beyond me , cant tell oh well thx for replying
eric39 is offline
post #4 of 9 (permalink) Old Mar 6th, 01, 02:09 PM
If the motor is a 2.2 liter you might be able to get them off from the bottom of the car.
wrench turner is offline
post #5 of 9 (permalink) Old Mar 7th, 01, 04:08 AM Thread Starter
wrench turner your correct talked to a guy at my auto store , its a 2.o motor for every two plugs there is one coil pack what ever bad plug wire you have that is not fireing you you take that off and install the pack , but easier said than done got find me a very small and long socket that fits then i can get it done , one of them thinghs were you buy a tool and use it once ,lol thx wrench turner
eric39 is offline
post #6 of 9 (permalink) Old Mar 8th, 01, 03:50 PM
I changed one last summer, and I put the car on stands high enough to pull the tranny. I also used a 2" extension mirror to find the bolts. And it was a PITA!
Nordbert is offline
post #7 of 9 (permalink) Old Mar 10th, 01, 05:46 AM
Go with the wood maul
68ragtop is offline
post #8 of 9 (permalink) Old Mar 10th, 01, 05:49 AM Thread Starter
i didnt pull the trans , just put it on the jack stands, bought a set of 1/4 inch long sockets ,7/32 was the size deep well , plus a 1/4 inch extension , and a screw driver that fits quarter inch sockets ,took the two bolts off pulled out the ign, coil placed the new one back on put the plug wires on it started right up no problem , then it quite on me again same problem , no fire in plug , it setr a while then it started up again , soo i unplugged the battery to reboot the computer , that worked then it did it again , **** im am soo pissed off at it any suggestions , couyld i bought a bad coil pack or is my computer the problem , car is a 88 cavaleir , 2.0 motor automatic thx guys , eric
eric39 is offline
post #9 of 9 (permalink) Old Mar 12th, 01, 12:53 PM Thread Starter
found out i needed a ignition module , which is behind both coil packs , what a bitch to put on take off both cooil packs well after you disconnect battery , then unplug the ign module unhook the 3 plug ins located on the bottom , then reinstall, easier said than done 100 bucks in parts 3 hrs to do saved a little bit of money thx for your comments now back to my cammaro , funner later , eric
eric39 is offline
