prob w/ rims - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 16th, 02, 04:18 PM Thread Starter
im having a prob i have these rims that are allunum thay keep loosin up and ive almost lost the weel 2times its getting anoin the lugs go inside the rim i dont know what they are called its on a 79 LT that i built i just want to know if there is a way to keep them on
chev876 is offline
post #2 of 4 (permalink) Old Dec 16th, 02, 06:06 PM
stevo camaro's Avatar
I would pull the wheel off, and then stick a lug in the hole & see if it goes past the flange of the wheel. Too long of lug nut maybe? Maybe you have a metric lug nut and it screws on, it seems, normally, but won't stay torqued.
stevo camaro is offline
post #3 of 4 (permalink) Old Dec 17th, 02, 02:44 AM
Wheel Mfg.s have a torque spec for their wheels, and on aluminum, its recomended to check at install, 50 miles and 100 miles.... due to the heat cycle. All Mfg.s are different, so check with them.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
post #4 of 4 (permalink) Old Dec 28th, 02, 10:42 PM
With the too deep of a run from a lug nut you might try the thick split lock washers like I'm running to keep the wheel from being a little loose and jiggling the lugs back out. There might even be just a little too much play between lug and wheel causing them to back out.
Snatchin'gears is offline
