2002 Camaro heat and ac issue - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 7th, 12, 07:39 PM Thread Starter
kimberly
I have a 2002 Camaro with a heater and ac issue. When using the heat or ac the air blows out fine and then all of a sudden it quits blowing. Sometimes it comes back on after a long while. I can hear air trying to come out but it doesn't. I've had my car to 3 mechanics and they can't find anything wrong. Of course the heat and ac work fine when the mechanics drive my Camaro. Very annoying. Any suggestions??
kimmyh63 is offline
post #2 of 3 (permalink) Old Nov 8th, 12, 10:59 AM
Vintage 68's Avatar
Re: 2002 Camaro heat and ac issue
Sounds like the Evaporator is freezing-up and preventing air circulation - and - the A/C compressor will be running even in heating cycles if you have the dual climate control type system ...
You can try shutting off the compressor using the A/C 'off/on' button (that flower/star symbol in temp. selection controls) on a day you need Heat, and see if the system air flow decreases like you have been seeing - if it doesn't, then you can guess it's the evap. freezing.
Have the shop check the A/C charge - it's most likely low on Freon
Slight chance it could also be a Vacuum issue - all the 'mix' doors are controlled by vacuum, so a leak will cause doors to be in wrong position.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Nov 9th, 12, 11:15 AM Thread Starter
kimberly
Thanks!!
kimmyh63 is offline
