85 camaro makes noises and shimmies - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 10th, 01, 12:36 PM Thread Starter
My 85 Camaro makes a whining noise when ever I start out from a dead stop. My G/F dad says it may be the Transmission. Also there is vibration from the rear end from a dead stop. And the front end has a lot of shimmy when I go over a bump or tracks at sertain speeds. Any ideas on what could be the culprit here?
jag2773 is offline
post #2 of 2 (permalink) Old Feb 13th, 01, 03:58 AM
better have a tech check out the suspension parts, as far as the rear shimmy, you really cant tell untill a tech looks at it. vibrations and noises tend to travel around and sometimes can be misleading.
I screwed up and put FixaFlat in my tire one time and it makes your tire out of balance, thus shimmy and shake.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
