Spark Plug Look Correct to You? - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 16th, 12, 10:04 AM Thread Starter
Charlie
My new ride with a 383 Stroker has a stall as you lift the clutch coming out of first gear (RPM's fall off and it dies unless you really gas it) and given I have never seen spark plugs where the top didn't come fully over the plug, I just wanted to know what you guys thought of these Autolites. It just doesn't look right to me and that's how all 8 of them look.
Charlie
Edmonds, WA
1969 Camaro SS Vert LS1 T56
camaromaniac is offline
post #2 of 10 (permalink) Old Nov 16th, 12, 10:19 AM
Marc
Re: Spark Plug Look Correct to You?
What is the part #?
SS69Cam is offline
post #3 of 10 (permalink) Old Nov 16th, 12, 10:32 AM Thread Starter
Charlie
Originally Posted by SS69Cam View Post
What is the part #?
Autolite
AR12
Charlie
Edmonds, WA
post #4 of 10 (permalink) Old Nov 16th, 12, 11:23 AM
Banned
Rob
satz28's Avatar
What plugs does the head mfg recommend?
What are the cam specs. There was another recent thread with somewhat of the same symptoms and the cam operating range I think started @ 2500 RPM or 3500RPM.
satz28 is offline
post #5 of 10 (permalink) Old Dec 5th, 12, 04:21 PM
Harry
dawg's Avatar
too blurry to tell?
434 stroker
US Navy retired
dawg is offline
post #6 of 10 (permalink) Old Dec 5th, 12, 04:44 PM
Chuck
The gap appears to be a bit wide unless that's merely due to the unfocused picture.
cnorton7311 is offline
post #7 of 10 (permalink) Old Dec 5th, 12, 10:17 PM Thread Starter
Charlie
Actually, I did a further search and it turns out these are correct and used a lot in racing!
Charlie
Edmonds, WA
post #8 of 10 (permalink) Old Dec 5th, 12, 11:45 PM
Tim
I thought the same, although it's hard to tell from the blurriness..... But would certainly check and adjust gap (if required).
Have you recently changed the plugs, or have you done anything else to the engine? Has it got worse with the onset of Winter? Could be a carb bog, rather than the plugs.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #9 of 10 (permalink) Old Dec 6th, 12, 01:39 PM
Was thinking along the line of carb issues, sound like a flat spot from off idle to power transition. I would look at pump squirter sizes, position of the cam lever, etc. AR12 is a cold plug. Try AR 42 for street.
TC # 349
zdld17 is offline
post #10 of 10 (permalink) Old Dec 6th, 12, 08:46 PM
PA Camaro Guy's Avatar
I also suspect the carb. The best picture to provide for reading the plug would be looking down on the face of it to be sure. However, to me it looks like your ground strap is black. Sooty strap is too rich. Should be the same toasted marshmallow color as the face of the plug (surface of the last thread that sees the flame). Also the color transition on the strap should be just beyond the bend of the ground strap running back to the plug body. This aspect indicates proper heat range.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
