Mysterious Rattling sound over bumps. - Team Camaro Tech
post #1 of 20 (permalink) Old Jul 23rd, 02, 06:28 AM Thread Starter
Hello all.
I have a mysterious rattling over bumps in my 1978 Z. I looked under the car with the wheels off the ground and found nothing loose. I then lower the car onto ramps to compress the shocks and again found no noise or evidence of the mystery rattle. The exhaust is tight and not touching the body. All the ball joints and tie rods are nice and tight too. As well as the shock mounts and all the bushings I could see. Please help. Thanks for trying.
1978 Z28 350 4 speed 3:73's.
http://www.cardomain.com/id/greenhornet350
Green Hornet is offline
post #2 of 20 (permalink) Old Jul 23rd, 02, 06:53 AM
Maybe somthing laying undreneath the back seat bottom. I had seat belts laying in there rattling around.
Black 69 camaro
HOTROD69CAMARO is offline
post #3 of 20 (permalink) Old Jul 23rd, 02, 07:49 AM
Rick
Try having someone go with you for a ride and sit in the back listening for any leads to the location. That'll narrow your search.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #4 of 20 (permalink) Old Jul 23rd, 02, 08:28 AM Thread Starter
It definatley sounds like something in the front end.
post #5 of 20 (permalink) Old Jul 23rd, 02, 09:30 AM
Rick
How about the sway bar brackets and end links? Pitman arm or idler arm?
Rick Dorion
RickD is offline
post #6 of 20 (permalink) Old Jul 23rd, 02, 09:32 AM
ZZ_430's Avatar
Trim rings or center caps?
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #7 of 20 (permalink) Old Jul 23rd, 02, 09:33 AM Thread Starter
Pitman arm is fine. So are the bushings on the sway bars. This weekend I'm going to jack it up and test the A-arms with a crowbar. I can't thing of anything else.
post #8 of 20 (permalink) Old Jul 23rd, 02, 02:32 PM
check the body mount at the rad suport the bushing rot and the bolts get play in them
drpm is offline
post #9 of 20 (permalink) Old Jul 23rd, 02, 03:39 PM
Maybe the Brake pads. Tim
TJMZ288 is offline
post #10 of 20 (permalink) Old Jul 24th, 02, 06:26 AM
How about a loose shock?
Black 69 camaro
post #11 of 20 (permalink) Old Jul 24th, 02, 08:01 AM
Are the tabs on the front outer brake pads staked tightly to the caliper. The outer pads will rattle like crazy if they aren't. Step lightly on the brake pedal when going over bumps and see if the noise stops.
Drew
69' X-11 350, Turbo 350, Factory Air, PS, PB, 12 Bolt (410 gear) & NOT AN SS
drew69 is offline
post #12 of 20 (permalink) Old Jul 24th, 02, 08:49 AM
Good stuff here. I'd like to add a loose catalytic substrate inside the converter
67 prostreet BB Camaro
80 z28 Camaro 355ci
71 BB SS Chevelle (clone)
2002 35th anniv SS Z28 conv.
Milan is offline
post #13 of 20 (permalink) Old Jul 24th, 02, 04:54 PM
I had a brake line rattling up on my frame that drove me up the wall for weeks!
sixt9d is offline
post #14 of 20 (permalink) Old Jul 24th, 02, 05:17 PM
Hello Green Hornet,
Have you checked to see if someone left you a present in your gas tank?
The Trickster!!!!!!!!!!!!!!!!!!!!!!
trickster is offline
post #15 of 20 (permalink) Old Jul 25th, 02, 02:21 AM Thread Starter
Wow Thanks to all you guys. Actually the noise is definatley comming from the front end. But this weekend I'm printing this page and going to check it out. The noise is driving me crazy.
