97 Camaro steering problems... - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 1st, 00, 07:06 AM Thread Starter
My 97 Camaro has started having a problem. I am thinging that the pump is not the problem. If I am sitting at Idle, I cannot turn the wheel, but moving and if I rev the engine up, then I can turn the wheels.... even if I sit still..
I am taking the car to the dealer in the morning to get it checked along with other things, but I want to go in a little educated so I don't get robbed..
Chadu
ChadU 97 Camaro 3800II, PST, SLP, y87
Chadu is offline
post #2 of 5 (permalink) Old Feb 1st, 00, 12:26 PM
start up and drive with the windows down and if you here a screeching sound maybe your belts are loose. Easy to fix yourself or someone even with a little experience with cars. Newer cars are quieter and it is harder to diagnose this problem with windows up.
MustangEater is offline
post #3 of 5 (permalink) Old Feb 1st, 00, 06:16 PM
Drake
Wink
I'm no expert but I would say that your 97 has a serpentine belt,these don't slip to easy,but I guess anything is possible.What kind of shape is the belt in?If you look at the underside of the belt where the grooves are,small cracks are normal on an older belt,deep cracks that run to the bottoms of the grooves or further means you need a new one anyway.Check your fluid leval also.Can you see any leaks in the P.S. hoses?If they are leaking this can cause the problem also.Just a few basic things to check.
67 RS RAGTOP # matching, 4X4 CHEVY TRUCK
67drake is offline
post #4 of 5 (permalink) Old Feb 2nd, 00, 03:16 AM
Might try www.alldata.com and see if there is a service bulletin on this for your car. Sounds like a pressure regulating problem.
tom3 is offline
post #5 of 5 (permalink) Old Feb 2nd, 00, 03:41 AM Thread Starter
Thanks for all your help.. the steering got way worse in the last couple of days so I turned the Camaro over to the dealer to get fixed..
I am pretty sure it's the pump.
ChadU
Chadu is offline
