1990 RS, possible electrical problem? - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 3rd, 01, 08:11 PM Thread Starter
Unhappy
Sorry for any non-technical descriptions, I'm not too knowledgable in the vehicle area. I recently bought a 90 RS, and after driving it for about 3 weeks it started doing strange things. The previous owner replaced the original radio with a newer stereo, and it randomly looses power for a few seconds every now and then. Sometimes it looses everything it had in the memory (programmed channels, time, etc), other times it just comes back on and everything is fine. It also happens sometimes when I use the power windows.
The latest thing that happened is that the stereo lost power, then the speedometer jumped from 35mph to about 55 and at the same time the rpm gauge jumped and the infl rest light flashed a few times. Any idea what might be causing this? I would appreciate any ideas or suggestions, thanks.
TheCamgal is offline
post #2 of 4 (permalink) Old Feb 4th, 01, 05:50 PM
I am not an expert electrical guy, but I would think it would be either a bad ground or the positive side of something could be grounding out. You should take it to a mechanic to be checked, because those cars are very much electrical and bad wiring in one of those can become very expensive if not fixed!!!
<UL TYPE=SQUARE> 67' Camaro 408" <LI>BBC, 598 HP. th400 3500 stall
<LI> 3.90 gears
<LI>best of 11.50 @ 118 MPH (Street Driven)[/list]
BRY67 is offline
post #3 of 4 (permalink) Old Feb 14th, 01, 05:17 PM
I have had the same problem in my 90 RS/SS. The factory computer in those 90 models start going bad and everything electronic starts going haywire...mine started causing the transmission to act really funky. Take it to a good mechanic and get it checked right away, or you will starting having worse problems all over the car.
Good luck!
90 Camaro RS/SS project (email for questions)
SpeedRacerSS is offline
post #4 of 4 (permalink) Old Feb 14th, 01, 06:00 PM
DjD
DjD's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by SpeedRacerSS:
Good luck!
<HR></BLOCKQUOTE>
Talk to me about a '90 SS!! I thought '72 was the last year until '96...
...Dennis
The Cars:
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
The Club:
Camaros Limited Nor-Cal
DjD is offline
