Hesitation on high rpm - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 15th, 01, 04:07 AM Thread Starter
fsr
Smile
The car hesitates on high rpm when over 3.000 rpm, the engine start without problems and runs fine in Park.
I don't have any codes and the light Service Engine Soon isn't on.
New EGR, Spark Plugs and wires, check valve, pcv valve, air pump, air filter, fuel pressure regulator.
(Camaro 1994 3.4 V6 103.000 Miles)
Any ideas?
Thanks for the help!
FSR
fsr is offline
post #2 of 6 (permalink) Old Jan 15th, 01, 06:32 AM
JohnZ's Avatar
Fuel supply restriction - check your fuel filter and lines and fuel pump pressure.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #3 of 6 (permalink) Old Jan 15th, 01, 08:03 AM
Rick
I had a similair problem and it was the fuel filter. Also, try some dry gas - can't hurt and you can be surprised how water can collect.
RickD is offline
post #4 of 6 (permalink) Old Jan 16th, 01, 03:38 AM Thread Starter
fsr
I put a new fuel filter, and the car it looks like better, but still hesitates when cold.
There is something else that I have to check?
Thanks!
FSR
fsr is offline
post #5 of 6 (permalink) Old Jan 17th, 01, 05:36 PM
go for a drive watching the fuel pressure you will see a drop if the pumps bad. also we have seen a couple wear out the cam on a 3.4
(at the GM store)
drews70camaro is offline
post #6 of 6 (permalink) Old Jan 18th, 01, 03:13 AM Thread Starter
fsr
Talking
Thanks!
I have a bad injector and I ordered a new kit.
See you in the highway...!
fsr is offline
