Muncie jumping out of gear - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 17th, 01, 06:06 AM Thread Starter
Joel
BlackCamaros's Avatar
I have an M-21 in a '69 that jumps out of all gears while coasting. Under load or normal driving, it works fine. However, if I back off the gas while coming up to a stop sign, or coast down hill, the tranny jumps out of gear. The shifter is set-up properly, and appears to be moving the shift levers full throw. Any suggestions ?
BlackCamaros is offline
post #2 of 3 (permalink) Old Mar 17th, 01, 07:26 AM
Sounds like you have a worn out shifter fork or one could be bent. had a similar problem years ago.
68 RS red w/ white stripes
67 SS/RS restoring
camaroguy is offline
post #3 of 3 (permalink) Old Mar 17th, 01, 09:27 AM Thread Starter
Joel
Could both forks be bent ? It doesn't matter which gear I'm in, 1,2,3, or 4, it pops out. I've even held the shifter hard in whatever gear I was in, and it would still pop into neutral. Any idea where I can get parts ? At one time I thought I saw muncie parts advertised through Richmond gear, but could'nt find anything on their web page.
