stering colum question. - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 5th, 01, 03:35 PM Thread Starter
I had a post on hear a week ago and ya'll helped alot. Thanks for the help! I need to know now were I can get a pivot pin remover. They dont have it at part stores and at the dealer ship. Thanks again for the help.
KEVY G is offline
post #2 of 6 (permalink) Old Dec 5th, 01, 04:01 PM
Get yourself a 10-32 screw about 1" long. Thread it into the pin. Take a pair of pliers and a screw driver and remove pin. Hope this helps.
jhow66 is offline
post #3 of 6 (permalink) Old Dec 5th, 01, 04:17 PM Thread Starter
Ive never taken one this far apart before.Does it screw out or just pull out.
KEVY G is offline
post #4 of 6 (permalink) Old Dec 5th, 01, 05:48 PM
Cool
Greeting Kevyg, the pivot pins pull out, the 10-32 screw gives you something to pull the pins out without damaging them. I hope that abundance of reading material gave you an insight into locating and correcting your problem.
Good luck! The Trickster!!!!!!!!!!!!!!!!!!
trickster is offline
post #5 of 6 (permalink) Old Dec 6th, 01, 05:17 AM
Paul
PDQUICK's Avatar
If you can't get the pins out with the 10-32 screw method, Snap-On makes an awesome pin removal tool. The bad part is that they get about $35 for a tool that is worth about $5!!
Just get some extra screws and try not to break them off in the pivot pins!!
PDQUICK is offline
post #6 of 6 (permalink) Old Dec 6th, 01, 02:47 PM Thread Starter
Smile
Thanks again for all ya'lls help. And thankyou trickster for all info.
KEVY G is offline
