Hei - Team Camaro Tech
post #1 of 3 (permalink) Old May 8th, 01, 04:26 AM Thread Starter
Red face
I Have a new summit hei and its not sending any spark to my wires. The wire to the battery side of the coil is hot. I put a light tester on the tach side and cranked the motor and the light came on and then slowly went out. Help
Brandont is offline
post #2 of 3 (permalink) Old May 8th, 01, 04:30 PM
im not really fam. with summits dist. but it sounds like a module problem
the mechanic is offline
post #3 of 3 (permalink) Old May 9th, 01, 06:54 PM
David Pozzi
davidpozzi's Avatar
The tach side should blink on and off when the engine is cranked.
Did you bypass the resistance wire in the wiring harness?
make sure it's getting 12 volts.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
