2 dead batteries HelP! - Team Camaro Tech
post #1 of 13 (permalink) Old Dec 1st, 12, 12:59 PM Thread Starter
Awhile back ago my car was having problems starting and it would stall often then after not starting my car for 3 days the battery was completely drained. Turned out the the alternator was shot. Bought a new one and charged the battery and everything was okay until i didn't start my car again for a couple of days and the battery was drained again. I have recently bought a good, used battery and i thought everything would be fine but again, i didn't turn my car on for a couple days and its completely dead. That's where i sit today and its been dead going on a couple of weeks now. HELP!!
FkA12 is offline
post #2 of 13 (permalink) Old Dec 1st, 12, 01:16 PM
Daryl
1968RallySport's Avatar
Re: 2 dead batteries HelP!
Disconnect negative battery cable. Install an amp meter in line between the cable you disconnected and the battery. Read current draw. Start disconnecting accessories until reading is below 50 mA.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #3 of 13 (permalink) Old Dec 1st, 12, 02:47 PM
Ammeter or a test lamp. If aftermarket radio is installed, some current will be drawn as Daryl suggests, for clock and presets.
No mention of year, if late model with an ECM/PCM, VATS or aftermarket alarm, current will always be drawn, or test light will glow dimly.
post #4 of 13 (permalink) Old Dec 1st, 12, 03:19 PM
Joel
joels's Avatar
I had this same problem on my Chevelle a couple of years ago. It wound up being an open ground. I dont remember how I found this but do a search and should find help. Good luck
joels is offline
post #5 of 13 (permalink) Old Dec 1st, 12, 09:14 PM Thread Starter
thanks everybody ill be looking into your tips ASAP. forgot to mention, its an 02 camaro SS with an LS1.
FkA12 is offline
post #6 of 13 (permalink) Old Dec 1st, 12, 11:24 PM
Daryl
FYI - 50 mA will show up as .050 A on a digital volt/ohm meter.
1968 Rally Sport
302ci
Muncie M22
post #7 of 13 (permalink) Old Dec 2nd, 12, 07:52 AM
Since an '02, check alt again. If doing the test lamp/ammeter test, be sure you know the security number for the radio, check test equipment, then disconnect red wire on alt BATT post, then check test eqt. Could be a defective regulator.
On my '00 SS, and with a seven year old Interstate battery, after starting once every week, charging system voltage at battery is 14.8 volts, as a guide.
post #8 of 13 (permalink) Old Jan 1st, 13, 11:07 PM Thread Starter
thanks everyone problem solved.
FkA12 is offline
post #9 of 13 (permalink) Old Jan 2nd, 13, 05:10 AM
Good to read, problem was?
post #10 of 13 (permalink) Old Jan 2nd, 13, 02:04 PM
prostreet69camaro's Avatar
You need to let us know what you found for your problem. This way other people that have the same problem will know what to look for.
prostreet69camaro is offline
post #11 of 13 (permalink) Old Jan 5th, 13, 04:54 AM
Harry
dawg's Avatar
LOL this is what burns me up after offering help!
No reply on what was the problem!
434 stroker
US Navy retired
dawg is offline
post #12 of 13 (permalink) Old Jan 5th, 13, 06:31 AM
alex
I agrree with DAWG burns me up too at least tell us what the problem was so we will know another thing or two about a thing or two.Alex
ss27 is offline
post #13 of 13 (permalink) Old Jan 5th, 13, 06:35 AM
69-Pace's Avatar
Patience is a virtue folks
His profile stats show "Last Activity: Jan 2nd, 13 03:56 PM" So hopefully he will return sooner then later to our community with all the answers and experience gained ready to pay it forward.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
