Service Engine Soon light - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 21st, 01, 06:36 PM Thread Starter
I just got my 1996 Camaro Z28 SS and the service engine light soon comes on all the time. The dealer said to disconnect the battery cable. (i guess this is the dealers way to get the light to go away). I have no idea what it could be, if you could give me some idea what it could be.
Thanks,
Kyle
FordKilla is offline
post #2 of 4 (permalink) Old Jan 21st, 01, 06:55 PM
DjD
DjD's Avatar
The owners manual says if the light is on steady it's the emissions stuff.. May still be under the emissions warranty.
...Dennis
The Cars:
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
The Club:
Camaros Limited Nor-Cal
DjD is offline
post #3 of 4 (permalink) Old Jan 22nd, 01, 02:20 AM
It sounds like time to find a new dealer. Sure, disconnecting the battery cable will make the light go away. That is until the problem develops again.
If you have access to a code scanner, plug it in and check the code. You can pickup these scanners at most larger autoparts stores for around $30. It will come with a book of related codes and will at least give you a direction to start looking.
As Dennis suggested it could be under emmisions warranty. But then again federal emmisions warranty in Ca. is 7/70. The rest of us are 5/50. How many miles are on the car and what is the month of the warranty start date? (You may have to find a dealer to tell you the start date.)
67 Camaro LS6 454/TH400/12bolt 3.73
1989 TransAm 5.7L WS6 W/all the options
www.geocities.com/akfourme/
cardude is offline
post #4 of 4 (permalink) Old Jan 22nd, 01, 05:21 PM Thread Starter
Thanks for the help.
There are 52900 miles on the car, the guy bought it brand new in May 96 I dont know when the warrenty started. I said dealer as in a used car seller. I am going to go out and get a code scanner and i will report the results.
