Shifting issue in '95 Z/28 - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 9th, 12, 07:31 PM Thread Starter
I've got a 1995 Z/28 Convertible, with a 4-speed auto. The car has 60K miles on it. I perform regular oil changes in the spring and only put about 3K miles on it a year.
Approx. 6 years ago, had all the fluids changed, but other than that, the car is factory stock (original). Starting this spring, whenever you floor it, once the RPM reach about 5K, it just starts choking/puking/cutting out/back firing. When you get out of the gas, it's fine. Any other time, it ABSOLUTELY purrs and runs like I've experienced over the 11 years that I've owned it. It DOES NOT throw any kind of "Service Engine Soon" code, and I've even plugged in my scan master to see if there was a code stored, however, there is not.
I'm completely lost as to why it's doing this. Any ideas?
Thanks in advance for any help.
Sincerely,
Chris
cbubya87 is offline
post #2 of 3 (permalink) Old Dec 9th, 12, 07:50 PM
omar
Re: Shifting issue in '95 Z/28
it sounds like the optispark is breaking up at high rpm check out ls1lt1.com for more info on lt1 mine never did that. check that web site a lot of good info on lt1 there hope it helps
67 rs
70 rs
95 z28
omarcamaro is offline
post #3 of 3 (permalink) Old Dec 9th, 12, 08:23 PM Thread Starter
omarcamaro,
Thanks!
Took your advice and signed up/posted accrodingly.
cbubya87 is offline
