95 camaro 3.4 - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 13th, 12, 04:32 PM Thread Starter
mike
95 camaro 3.4
Hi, so my car smokes white which i belive is water although it smells like gas. I no its running rich becaus my mpg is around 8. It studders slightly and pops at high rpm. Any advise??
mikester1210 is offline
post #2 of 8 (permalink) Old Dec 13th, 12, 08:46 PM Thread Starter
mike
Re: 95 camaro 3.4
Anyone... please.
post #3 of 8 (permalink) Old Dec 14th, 12, 03:53 AM
Re: 95 camaro 3.4
Welcome, Mike.
Off the cuff, running rich could mean the engine mgmt system is in choke mode,
I would probably check the two-wire coolant sensor to see if it is either unplugged or corroded, maybe an unplug and reconnect the connector.
You might measure across the coolant sensor terminals with an ohmmeter at both engine temperatures of cold and operating temp, ensuring the sensor reads less ohms at operating temp, and the harness still id connected to the ECM.
Also, the first check would be to the local Advance Auto and borrow the code reader to see if a code is set. Usually, the CHECK ENGINE light is on. Since you did not mention the CEL, I suspect it is not on, or burned out. There si a CEL bulb check when ign is in IGN position, then the light goes out.
Could be a leaky injector, Run a can of injector cleaner with the next full tank.
Air filter could be clogged also and in need of changing.
You might buy a Haynes manual and read up.
post #4 of 8 (permalink) Old Dec 14th, 12, 01:04 PM Thread Starter
mike
Re: 95 camaro 3.4
My fan dosent come on. I bought the new coolant temp sensor and installed it, but fan still dosent come on. I dnt no why... I ran injector cleaner and even seafoam. I think the fan not comming on is a good place to start because correct me if im wrong, the temp sensor should turn the fan on.
post #5 of 8 (permalink) Old Dec 14th, 12, 01:06 PM Thread Starter
mike
Re: 95 camaro 3.4
Also the light comes on for a min when i put the key in but goes out. If i let off the gas pedal in gear some times it comes on but goes out after i start it back up.
post #6 of 8 (permalink) Old Dec 14th, 12, 03:39 PM
Re: 95 camaro 3.4
Fan is controlled by the PCM, Power Control Module, at two events, 1) engine coolant above 235°F, one fan, and when MAX A/C is selected, both fans, if equipped with two.
CEL coming on & off is good bulb check at turning ign sw to IGN before START.
However, CEl coming on at decel is a problem and may set a trouble code.
As suggested, go to an auto parts store and borrow code reader to find trouble code set. Then look up trouble code(s).
post #7 of 8 (permalink) Old Dec 15th, 12, 11:19 AM Thread Starter
mike
Re: 95 camaro 3.4
Ive tried autozone but this year has a obd1 comp n obd2 connection. Says no link. Fan dosent even come on with ac on.
post #8 of 8 (permalink) Old Dec 17th, 12, 05:05 PM Thread Starter
mike
Re: 95 camaro 3.4
Someone help me please. This is my dd and its costing way to much to drive my baby...
An inch or a mile, winning's winning
