Vibration - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 16th, 01, 10:38 AM Thread Starter
Any body ever have a clutch or pressure plate cause a vibration? Especially a Center force dual friction that was trans planted from my old motor?
Life begins at 140...especially in a 1967 Camaro Z28!!
joeyj is offline
post #2 of 5 (permalink) Old Jan 16th, 01, 12:45 PM
I had a wicked vibration coming right up through my shifter. Turned out the pressure plate had shifted inside the housing. Ended up replacing the thing and its been real smooth since.
Paty
73 Z28/LT
Paty is offline
post #3 of 5 (permalink) Old Jan 16th, 01, 02:02 PM
Yes, I had a problem with the Centerforce pressure plate's centrifugal weights. They at times would not quite find a balance. I have also seen them loose a weight and work great, but with a vibriation.
Try to put some movement on the weights with the end of a hammer (wood end) into the clutch fork window and chech to see if they move freely.
chacane67 is offline
post #4 of 5 (permalink) Old Jan 16th, 01, 04:27 PM Thread Starter
Thumbs up
well I am glad I am not the only one who has trouble with those centerforce weights!! I had already removed the weights and have run the car since and it seems to work ok, I just wont be running my slicks for now. Even though I have removed the weights I still have a vibration it is less though. I think I will have to go with Patys sugestion and replace the whole pressure plate assy. Thanks guys!!
joeyj is offline
post #5 of 5 (permalink) Old Jan 17th, 01, 11:02 AM
Z28 Mark's Avatar
I have Center Force Dual Friction in my 73 Z28 for about 4 months now. I have had no trouble with it. I thought that it would be too much clutch for the car (basically stock) and I would hate the thing, but I think itís the best thing that Iíve done to the car so far.:O
Mark (a.k.a. Z28 Mark)
Z28 Mark is offline
