1995 3.4 camaro - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 20th, 12, 09:59 PM Thread Starter
mike
Exclamation 1995 3.4 camaro
Hey guys, so my camaro has been popping from the intake it sounds like. I belive its choking and dumping too much gas in. Fuel consumption is through the roof, and loss of top end power. I could really use advise, it is driving me crazy...
An inch or a mile, winning's winning
mikester1210 is offline
post #2 of 2 (permalink) Old Dec 21st, 12, 04:13 AM
Re: 1995 3.4 camaro
You might begin looking at the two-wire coolant sensor.
Unplug it, clean contacts as ggod as you can, reconnect.
While its unplugged, measure across the two pins for resistance, should be above 5Kohms. When at operating temp, it should read around 150 ohms to 200 ohms.
Also check for intake gasket leaks, the rubber bellows between the MAF and intake for cracks, any vacuum hoses loose or cracked, dry rotted, broken plastic vacuum lines, this may include the heating system as vacuum controls the doors.
Run a can of injector cleaner in the next full tank of gas.
might need an air filter change and a spark plug change.
Some ideas.
Is radiator full? If coolant is low, it will never heat up the coolant sensor and ECM will always stay in 'cold' mode.
