my '68 won't start - Team Camaro Tech
post #1 of 7 (permalink) Old May 29th, 01, 01:19 PM Thread Starter
I recently rebuilt the front end on my 68, 327, 3-speed. I got it started once, and did some distributor work, adjusted timing etc. and now getting spray pulse from the carb. Sometimes it even catches fire! I think it's a timing issue, but put #1 cylinder in compression stroke, checked rotor to number one wire, etc. and still she won't fire up! Any ideas?
thewhit is offline
post #2 of 7 (permalink) Old May 29th, 01, 06:46 PM
BTC
Sometimes if your timing is way off you can get your buddy to rotate the distributor 1/4 turn each direction while your are cranking over the car. If it sounds better and starts to fire as you twist the distributor you know your are getting close to the correct timing.
68/Z28,35O LT1
RICHMOND 5 SP,
BTC is offline
post #3 of 7 (permalink) Old May 29th, 01, 08:15 PM
Dale
Are you sure the firing order is correct? Clockwise rotation-18436572,odd cyls on the drivers side.Double check 5 and 7,they are easy to mess up.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #4 of 7 (permalink) Old May 30th, 01, 02:40 AM
Steven
I agree with dale ... it would seem that you have a couple of plugs wire crossed ... this could make the cylinder fire when the intake valve is open and send flames back thru the carb ...
sdtsdt is offline
post #5 of 7 (permalink) Old May 30th, 01, 02:43 AM Thread Starter
Wink
Thanks for the tips. As far as I can tell, the firing order is correct. We'll try turning the distributor while cranking. Good idea. Any thoughts on why we're getting so much spray coming out of the carb? We checked the spark to number one and it's good and hot. Fuel pump seems OK too.
thewhit is offline
post #6 of 7 (permalink) Old May 30th, 01, 06:41 AM
Steven
WHen you say distributor work, I am assuming that you pulled the distributor out and re-installed it. Otherwise, you should be able to start the car by turning the distributor as you crank it until you "find" a good spot. Check the rest of your ignition system wiring as well as re-check any work done under the distributor cap. If points, check points gaps ... capacitor may be bad . Once again, you get fire when cylinder sparks while intake valve open ...the carb pulse may be in sync with fuel pump .. make sure float is closing gas inlet when carb is "full". And "walk" every spark plug wire all the way down to correct cyl ( 1 3 5 7 on driver side 2 4 6 8 on passenger side .. numbers are from front to back ).
sdtsdt is offline
post #7 of 7 (permalink) Old May 30th, 01, 02:27 PM Thread Starter
Thanks again sdtsdt. I'll give this a try. Lots of good advice, and very appreciated.
thewhit is offline
