CARB HELP!!! - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 11th, 01, 05:44 PM
rogleete
Guest
Posts: n/a
Exclamation
I have the worst time with carbs.. I'm on my 3rd one, 2 holleys and now a supposively "no maintenance out of the box running" edelbrock 600cfm manual choke carb
it was working fine..now it seems to be flooding out for some reason, when i hit the gas I hear a loud hiss of air getting sucked into the carb i assume..then at idle it will eventually stall out, give a little hiss and a puff of smoke..then the dripping sound of gasoline.. whats up with this??
'69 Camaros SS 350, red w/ white Z28 striping. .030 over, 9" rear, 3.89 gears, 700r4
post #2 of 8 (permalink) Old Feb 11th, 01, 08:09 PM
Dale
Are your sure the carb to intake gasket is sealing?(no vaccum leak) Did you replace the fuel filter? What did the old one look like,any dirt in it? Dripping gas, sounds like the float is stuck.Do what I would do --- HIT IT WITH A REAL BIG HAMMER-----carefully----
68 z28 68 rs 327 73 454 vette
dale68z is offline
post #3 of 8 (permalink) Old Feb 11th, 01, 08:35 PM
Every carb needs fine tuning and it's a good thing to know. If you email me I can help better. I need to know what engine compression blah blah blah.
67stock is offline
post #4 of 8 (permalink) Old Feb 12th, 01, 04:06 AM
rogleete
Guest
Posts: n/a
I was wondering..which vacuum ports should i cover or leave open. there is 3 on the edelbrock that i know of. 1 is the PCV to the valve cover, then 2 smaller ones which i have both covered by the rubber covers supplied. the car has mallorey distributer, .292 split dur cam, stock heads, RPM intake...i have no idea what the timing is nor what it should be
post #5 of 8 (permalink) Old Feb 12th, 01, 04:07 PM
This may not be a carb problem at all...9 times out of 10 the carb is blamed when it is an ignition problem. It concerns me that you are replacing carbs and stuff and dont know what the timing is...I dont mean to be rude but come on...you dont know what the timing is set at? If you dont know how to set it, find someone that does (and have them show you how) and get it checked...it sounds to me like the timing may be way retarded. Set it at 12 degrees initial for a baseline...that may not be best for your combo but it will get you in the ballpark. Cover the basics first...its a lot cheaper than replacing carbs. I am not trying to be an a$$, just trying to help.
Oh, and one more thing...none of the vaccuum ports should be uncovered. I noticed you didnt mention the power brake port...if it isnt closed off you will have a big gaping vaccuum leak.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
[This message has been edited by travis (edited 02-12-2001).]
travis is offline
post #6 of 8 (permalink) Old Feb 12th, 01, 05:12 PM
Steven
The fact that you say the car is flooding suggests that you should check your fuel pressure. Are you running a regulator? DO you know what kind of fuel pump that you have?
sdtsdt is offline
post #7 of 8 (permalink) Old Feb 12th, 01, 05:15 PM
rogleete
Guest
Posts: n/a
standard plane stock fuel pump, I've been looking into the ingnition stuff. this might be were the problem is. I plan on getting the timing checked/set tomarrow. would an MSD6a box be of any help to my engine. what do they really offer to benefit?
post #8 of 8 (permalink) Old Feb 13th, 01, 05:13 AM
Steven
I would not worry about the MSD box yet. Sometimes enhancements will mask a problem rather than solve the problem ( just like the car running fine for a while with the new carb ). Get the car running fine with the basic setup to establish a benchmark...then you can make changes and be able to assess those changes. Also, don't change a lot of things at once ... that makes it more difficult to know what works or doesn't work. Go through the distributor, the plug wires, and even the plugs and make sure that your fuel pressue isn't too high. Get the timing set and then assess where you are. Go to a garage if necessary ... you may want to fix it yourself, but guessing and changing parts can get to be expensive...for example, an Edelbrock 600 cfm barb is $200 + ...
sdtsdt is offline
